<~----> Fan advice please! - Hardware Canucks
Old September 27, 2010, 07:45 AM
Default Fan advice please!
Hey guys,
I recently ordered parts for my i5 760 build and would like some advice on cooling.
The computer is being built for running SC2, Civ5 and D III when it comes out. Other than that it will be a general PC for whatever fanciful things I decide to do.
Overclocking, perhaps, but probably not intially. I have a ton of reading to do before I jump into that one.
Here are the components for my build...
Case - Antec 300
PS - Seasonic S12II 620W EPS12V 20/24PIN ATX Power Supply Active PFC 80+ Bronze 6+8PIN PCI-E W/ 120MM Fan
Mobo - Gigabyte H55M-USB3 mATX LGA1156 H55 DDR3 1PCI-E16 1PCI-E4 2PCI HDMI Sound GBLAN USB3.0 Motherboard
CPU - i5 760
Heatsink - CoolerMaster Hyper 212
Video - XFX Radeon HD 5770 850MHZ 1GB 4.8GHZ GDDR5 2XDVI HDMI Display Port DIRECTX11 PCI-E2.0
HDs - Kingston 64gb SSD and Seagat 1TB
RAM - G.SKILL F3-12800CL9D-4GBRL Ripjaws PC3-12800 4GB 2X2GB DDR3-1600 CL9-9-9-24 Core i5 1.5V Memory Kit
I'd like to know what additional cooling I might need and where it should be placed with the Antec 300 case. Also, if anyone can offer overclocking advice I certainly won't turn it down. Lastly, any suggestions regarding 120mm fan selection would also be appreciated, noise level is #1 followed by airflow.
Cheers and thanks in advance!
Old September 27, 2010, 09:30 AM
Soultribunal's Avatar
I've had really good success with these fans on the quiet front so far.
http://www.ncix.com/products/index.p...olutions%20Ltd.
That being said, I myself go for the screamer fans that usually annoy anyone else namely because I like best temps over noise :)
ST
Fan advice Kilauea Air Cooling 3 October 15, 2009 04:59 AM
zalmaan 6 fan, fan controller quikgp Peripherals 4 May 29, 2009 09:32 PM
Need fan advice. Caznoob Air Cooling 3 January 29, 2009 12:20 AM
4870 fan: Catalyst auto-fan is too aggressive Bucklaz Video Cards 4 January 7, 2009 11:21 AM
FS: fan hDD cage w/ 120mm lighted fan, cpu funnel, pentium 1 elninio Buy/Sell & Trade 7 June 20, 2008 12:18 PM
