Old September 23, 2010, 02:48 PM
martin_metal_88's Avatar
Default Best choice according to you?
So guys, long story short. I need some money so I will sell my loop and I need a good air cooler. I wont run the stock cooler for long ho no XD. So, you know me I will oc but I can't decide which cooler to get :(.
Here are all the one I have in my list.
Not really sure about this one but it's a choice.
http://www.ncix.com/products/index.p...acture=Corsair
Already owned a prolimtech have been please with it but not sure again.
http://www.ncix.com/products/index.p...re=Prolimatech
With 2 fan on it would it be rock solid???
http://www.ncix.com/products/index.p...e=Thermalright
3 fan on it??
Black si so sexy...would look cool with 2 blue UV fan no?
Review have been good, but I don't like plastic that much. If it's so much better I will take it but I need advice.
http://www.ncix.com/products/index.p...e=COOLERMASTER
Old September 23, 2010, 02:52 PM
3.0charlie's Avatar
http://www.ncix.com/products/index.p...facture=Noctua
Hydro-Quebec is salivating...
Old September 23, 2010, 02:56 PM
That was fast reply. I already concider the DH14 but I get it off of my list since it can only fit north/south in my ATCS and I want a east/west coolerI am a real girl about this
Old September 23, 2010, 03:05 PM
Assuming you already have a few decent fans lying around I see no reason to get anything but the Prolimatech. Unless you're changing to an AM3 build that is, or you don't have the space.
Old September 23, 2010, 03:51 PM
3.0charlie's Avatar
Ok then. Triple fans. http://www.ncix.com/products/index.p...e=Thermalright
Old September 24, 2010, 07:08 PM
Soultribunal's Avatar
Zalman Flex, and if you're lucky perhaps the Gelid WIng 12 PL will actually be in stock at NCIX soon.
Solid Fans, I've had one for a while.
ST
www.realhardwarereviews.com
Old September 24, 2010, 08:31 PM
no love for the v6gt?
Old September 24, 2010, 08:48 PM
Rye 1080's Avatar
Between most high end air coolers, they all fall within a few degrees of each other when using similar fans.
So its largely aesthetics, personal opinion
Then the fans that come with it or the ones you get, basically boils down to how loud you can handle.
I have two deltas rated at 44dba on my Thermalright Venomous X, and they don't bother me, but would drive many people nuts.
Old September 24, 2010, 09:28 PM
ST
Why to wait for NCIX to have them stock when I have 6 or 7 laying in my fan box So ST you would go for the flex, interesting...I have to add it to my list then
Old September 27, 2010, 09:15 AM
The Flex is an awesome Cooler, a real improvment from Zalman for sure.
And the wing 12 fans which should be at NCIX soon (I had 1 ahead of Canadian Release ) should compliment it well as I had very good experience with them. They might even release my vaunted R4's from Coolermaster, and that is really saying something.
ST
If you had the choice.. _dangtx_ Off Topic 11 September 4, 2010 02:31 AM
Which one is a better choice? BootlegUsher Power Supplies 4 December 21, 2009 03:04 PM
which is these is the best choice for me Bobobear New Builds 14 November 27, 2009 05:58 PM
Need some help on this choice monkey_mo CPU's and Motherboards 3 June 27, 2009 06:54 PM
Choice of MB...? Prof. Dr. Silver CPU's and Motherboards 21 January 9, 2008 03:35 PM
