-   Air Cooling (http://www.hardwarecanucks.com/forum/air-cooling/)
-   -   monitoring temps (http://www.hardwarecanucks.com/forum/air-cooling/36451-monitoring-temps.html)
eagle_eye September 21, 2010 04:52 PM
monitoring temps
What do you guys use to monitor temps?
Software or physical probes?
dustin1706 September 21, 2010 05:38 PM
It's pretty hard to get a physical probe on anything with a heatsink on it (CPU,GPU) There is really no accurate method that I know about.
Realtemp is good for CPU/GPU temp monitoring. (depending on your GPU)
If running an ATI card, then atitraytools is good. MSI afterburner is another good one.
If you want onscreen temps, FPS etc in games then Rivatuner can be used in conjunction with everest to provide GPU and CPU info.
eagle_eye September 21, 2010 06:01 PM
thanks for the tip....
i'll lokk into it
_dangtx_ September 21, 2010 06:12 PM
everest, been using it since it was called aida
lowfat September 22, 2010 01:32 PM
Moved over to Everest recently. As it can read almost everything. Plus the fact that it can also output everything to the LCD on my G13.
Slik September 23, 2010 07:51 AM
Real Temp. Temperature reports are as accurate as you will get from any other source.
martin_metal_88 September 23, 2010 09:28 AM
Real temp Everest are good. Some time your mobo come with a software you can also use it. You also have to look what part you want to monitor. If you awnt the video card temp then MSI afterburner is pretty nice. Everest is doing good in this also. Use everest for all the other part.
mo' power September 23, 2010 11:33 AM
I still use core temp. Been using it for years.
