-   Air Cooling (http://www.hardwarecanucks.com/forum/air-cooling/)
-   -   E8400 Temps (http://www.hardwarecanucks.com/forum/air-cooling/36384-e8400-temps.html)
mattydies September 19, 2010 10:28 PM
E8400 Temps
The weather is cooling off and I have resumed overclocking my computer (in sig). I am currently running at 4.4Ghz (Stable so far :clap:). At the moment I am pumping 1.3V into the core. I went high power after hitting 4.0 on stock volts. I did not 'step it up' so I am hopeful there will be room to drop my V-Core.
I ask the age old question - HOW HOT IS TOO HOT?
For extended stability testing? (Hours of Orthos)
For a moments 'peak' temp?
For idle?
My idle is low to high 40's right now. It seems to go up and down. I have seen her peak @ 71c under OCCT thermal testing which concerns me. I have an Ultra 120 cooler which I need to rotate 90 degree's to take advantage of the large fan on the top of my case (Antec 900 - 200mm). Also I have had suspicions in the past that re-applying thermal compound may be beneficial. I hope to do this in a day or two (I have to unload a moving truck to get my IC7).
Looks like I may be upgrading my case fans sooner than I thought. I am thinking some new Noctua NF-S12B FLX 120M fans and a nice dial type fan controller.
mattydies September 19, 2010 10:38 PM
~*~ ALSO ~*~
I have 2 - 120mm fans in the front, 1 - 120mm in the rear, and I had to remove the 120mm in the window as it was in the way of my cpu cooler. The fans are ok, but nothing special.
FYI I have booted Windows @ 4.66Ghz (with further a voltage increase) but almost instantly crashed upon starting stress testing.
burebista September 19, 2010 10:53 PM
Keep distance to TJMax>20 (aka max core temps 80C) in daily use and happy overclocking. :thumb:
gingerbee September 20, 2010 05:52 AM
yup that's how rn things to 80c or 20c away from tj max
Coach September 20, 2010 10:58 AM
I own an e8400, I had no idea I could run it up to 80C max. OP please continue to post your OC results including temps and voltages. Thanks
