Old September 8, 2010, 09:28 PM
well its decent, output wise. the noise levels, if you tune it down are not too bad either :) ramp it up and well your cat will not sleep next to your computer anymore.
Old September 8, 2010, 10:18 PM
jcmaz's Avatar
I hope you know about the side fan issue regarding tall CPU heatsinks.
You must install the side fan on the outside of the case because the fan interferes with the CPU cooler.
-Plato
Old September 8, 2010, 11:01 PM
Already modded the side fan to the outside :)
Old September 10, 2010, 04:40 PM
Installed everything today and I must say its one hell of a big difference, my temperatures dropped from 36 to 20 on idle. Had to keep the coolermaster fan on due to ram fitting issues
[FS] Noctua NH-D14 CPU Heatsink alexroland Buy/Sell & Trade 1 April 20, 2010 09:39 AM
Should i change my cpu heatsink? MrFoxx Air Cooling 15 May 14, 2009 11:02 PM
new cpu heatsink Evylldemon Air Cooling 6 November 10, 2008 04:03 PM
Suggestions for a CPU heatsink? Jon_di2 Air Cooling 13 August 17, 2008 02:57 PM
CPU heatsink supgrade mattydies Water Cooling 22 November 7, 2007 09:33 PM
