-   Air Cooling (http://www.hardwarecanucks.com/forum/air-cooling/)
-   -   help choosing fans (http://www.hardwarecanucks.com/forum/air-cooling/35886-help-choosing-fans.html)
sempifer September 3, 2010 04:51 PM
help choosing fans
sup guys i recently bought a thermalright venomous x black for my 1055t cpu and i dont know which fans will fit i know they should be 120mm fans but when i search on ebay they say "120mm case fans"....will these fit my cooler?
please recomend me some fans.
AkG September 3, 2010 05:12 PM
basically any 120mm x 25mm thick fan will fit with the stock mounting equipment.
Some good, cheap, powerful (static pressure) fans which also move a good bit of air is the Cooler Master R4s. They get LOUD at full speed but are very well behaved at lower voltages. Let your mobo auto fan speed adjust and it will only ramp up when it NEEDS to.
NCIX.com - Buy Coolermaster R4-L2R-20CR 120MM Red LED Case Fan 2000RPM 90CFM 19DBA 3/4 Pin - r4-l2r-20cr In Canada.
They come with dif LED colours...so if led lighted fan is not your thing. You wont like them. Another good option is the various Scythe SFlex fans. Good, powerful but a bit more pricey.
NCIX.com - Canada's Premier Computer Store - Great Technology, Service and Selection.
sempifer September 3, 2010 05:23 PM
thanks...will get them green. love them
