<~----> Cooler Master V6 GT CPU Cooler Review Comment Thread - Hardware Canucks
Old August 30, 2010, 08:30 PM
SKYMTL's Avatar
HardwareCanuck Review Editor
Default Cooler Master V6 GT CPU Cooler Review Comment Thread
Shaped like a bona fide V6 engine, Cooler Master's new V6 GT heatsink is aiming to knock several high end coolers off of their respective thrones. To accomplish this, the V6 GT is equipped with a pair of high speed 120mm fans and enough cooling mass to beggar most of its competitors. However, can its performance belie an asking price of under $60?...
[ Read full article ]
Old August 30, 2010, 09:19 PM
nice. modern mobos should have no issues with 1.4amps on one fan header . and man those are fans.
shaving 10c on the 212+ can be considered a feat, probably worth the 2.5x price difference!
Old August 30, 2010, 09:23 PM
The price for this heatsink is supposed to be $57. The Hyper 212+ is $29 at NCIX. That's not a 2.5x difference.
Old August 30, 2010, 10:36 PM
SugarJ's Avatar
Wow. I actually really like the aesthetics of this product. Maybe it's just the fancy lighting catching my attention.
Very solid performance, will probably be around $65 Canadian street price. Good option for air cooling. This will be on my short list to try out, I think.
The Hyper 212+ is $23.60 at Direct Canada, and regularly goes on sale for $19.99. His math isn't too far off.
Edit: Here's a methodology/chart question. Because AkG takes all these coolers, and tests them with different fans at different loads, would a "best case" scenario graph be possible or more desirable? For instance, the Gelid Tranquilo works best with the Scythe G fan according to how I read the chart. So one page with 3 CPU speeds, and a direct comparison of each HSF with it's most optimal fan at that CPU speed? It wouldn't require any more testing, just compilation of a different graph. We see the same idea when he includes the stock fan results on the low, medium and high speed fan tests. And it would basically give you the "best" HSF results all on one page.
Old August 31, 2010, 12:02 AM
bovine.baron's Avatar
That is one very sexy and very smart cooler. I wonder what the different between the GT and the regular V6 is though.
Old August 31, 2010, 12:41 AM
MacJunky's Avatar
No. It has a plastic cover like that of pretty much any modern engine be it I4, V6, V8 or V12.
Too much plastic crap. DNW!
Performance aside, my hairy posterior in tight leather would look better than the ugly plastic crud covering this cooler. >_<
Old August 31, 2010, 12:46 AM
Lpfan4ever's Avatar
Seen the V6GT a while back on NCIX and was wondering how well it did. Good to see Cooler master kicking more and more ass.
Originally Posted by encorp
Code:
<firebane> slightly used
Old August 31, 2010, 07:10 AM
Sushi Warrior's Avatar
How about a chart with performance/degrees per fan RPM? To see if it is best at low speed or high speed.
You're half way through some post and you realize it's from some retard who types like he's got an array of dog dicks for fingers
Old August 31, 2010, 08:19 AM
bojangles's Avatar
I don't really see the point of that. I like it the way the review does it, that way we can decide if a low/high/stock fan is good enough. Turns out that the stock fans are amazing.
Actually, now that I think of it, the review DOES show if it's best at low or high. It's just on 3 separate pages...which makes sense.
Old August 31, 2010, 08:31 AM
rapmaster's Avatar
One thing I like to see is instead of two low RPM fans for the dual fan test, go with two high RPM fans.
Quando omni flunkus moritati
Cooler Master V10 CPU Cooler Review Comment Thread AkG Air Cooling 60 October 22, 2011 01:52 AM
Cooler Master Hyper 212 Plus CPU Cooler Review Comment Thread AkG Air Cooling 268 April 16, 2010 03:23 PM
Cooler Master Storm Scout Review Comment Thread lemonlime Cases 25 June 25, 2009 09:45 AM
Cooler Master V8 CPU Cooler Review Comment Thread AkG Air Cooling 37 June 15, 2009 10:37 PM
Cooler Master Hyper N520 CPU Cooler Review Comment Thread AkG Air Cooling 3 June 8, 2009 07:54 PM
