<~----> P5Q, Antec 300, Thermalright Ultra-120 - Hardware Canucks
Old August 13, 2010, 07:27 PM
Default P5Q, Antec 300, Thermalright Ultra-120
Can anyone help me with this? Advise???
I'll be putting all these together soon. I don't know what 120mm fan to use. I was thinking of getting a Noctua but I do have a S-Flex fan handy. This isn't built yet. I'm using the Q6600 from my current computer (being loaned at the moment). I think the wire clips are a pain so I was wondering if I should use a Thermalright fan holder. Do *all* 120mm fans fit in those?
I hope someone who owns all of these or at least the mobo and the heatsink can comment. Or if you just know! :)
Also, it seems that users who just have the black fan holder only use one fan while I notice a lot of the setups with the wire clips are using two fans. Does it matter? Some users claim about two degrees difference when using two fans but I guess that's not significant, huh?
I went by the pics in these links:
T.R.U.E 120 .... any users running 2 x 120mm as "Push & Pull" Fans ... ? - Overclockers Australia Forums
Thermalright Ultra-120 eXtreme-775 RT | Maximum PC
i7 950 stock running hot !!! help plz - techPowerUp! Forums
My current fans are Yate Loon 120mm, Scythe S-Flex-F 120mm and a SilenX 120mm (who cares, right? lol). The Antec 300 has some Tri-Cool fans and I read they're loud so maybe I'll replace them later. With the cooler orientation in a P5Q mobo (no Pro, SE, just basic model), I'm wondering how to set this up. I'm ordering a few components so I was wondering if I should get anything to add to the set up (extra clips for 2nd fan or fan holder).
Edit: I wasn't sure where to post this... 'new builds' or 'case mods' or what. I invite to move the post to wherever it's most relevant. My apologizes if it belongs somewhere else. Thanks.
Old September 8, 2010, 01:18 PM
No replies and a bunch of views?!? I guess I asked the wrong things or it's a boring thread?!? OOPS!
Can anyone tell me if this is the East/West cpu heatsink position for this mobo?
http://n7.slayernine.com/files/P5Q-D...s/IMG_2657.JPG
Old September 8, 2010, 03:43 PM
The fan holders only fit 25mm thick fans. The good news is that most 120mm fans are 25mm thick, so that shouldn't be a problem. However, I think you should just use the wire clips. They really are not that difficult to work with.
The version of the TRUE that comes with the black fan holder only includes one, whereas the version with the wire clips includes two sets. If you want to mount two fans with fan holders, then you need to buy one separately. That's why most people with that version of the heatsink only use one fan.
That is the east/west orientation.
Old September 8, 2010, 08:24 PM
Thanks, Zero!! 'Glad to get a reply on this. That's news I wasn't aware of.
I found the clips to be a pain. I guess I was doing something wrong. But, I did look at a few images in which the clips were used. Also, if you drop them and they disappear, that could be a problem. :) The fan holder seemed to eliminate potential issues or hassles. But, not sure if I want to spend $12 on one of them or double that for two.
Have you heard of anything about modifying the backplate?
Thanks again for the reply. I hope to have this set up real soon.
Old September 8, 2010, 08:38 PM
I don't know anything about modifying the backplate. I don't see why you would need to unless there's some interference.
Thermalright Ultra-120 not so great? Infiniti Air Cooling 63 July 15, 2008 12:21 PM
FS: Thermalright Ultra 120 Extreme JD Buy/Sell & Trade 5 July 14, 2008 03:49 PM
Thermalright ULTIMA-90 Thermalright Ultra 120 Mulder Air Cooling 4 April 27, 2008 02:08 PM
Antec 900 and a Thermalright Ultra 120 CasheKicker Air Cooling 22 March 30, 2008 05:02 PM
Thermalright Ultra 120 & 120 Extream, Difference? CasheKicker Air Cooling 5 March 6, 2008 10:16 AM
