Old August 12, 2010, 08:32 PM
SKYMTL's Avatar
HardwareCanuck Review Editor
Default Prolimatech Samuel 17 CPU Cooler Review Comment Thread
CPU coolers specifically designed for small form factor applications are few and far between but Prolimatech has now thrown their hats into this ring with the new Samuel 17. Able to mount a 120mm fan, this low-slung cooler is looking to bring some high performance to HTPC and SFF users....
[ Read full article ]
Old August 12, 2010, 09:11 PM
martin_metal_88's Avatar
Pretty nice review AkG, I was actually looking to buy one for my futur HTPC. I think you put a big stop on my go XD. But well I do have 2 question for you. If it's a HTPC cooler, wouldn't it be better to test it on a horizontal system ( unless I missread ) because like 80% of real HTPC in small case are horizontal and not vertical??
Second question is open to everyone. Which is then the best small cooler to OC a I3 or I5 in a HTPC. The case will be a Silverstone Lascala LC17B.
Awesome review like always my friend!
Ask for more
Martin_metal_88
Colenzo : See system spec!
Odysseus : I7 860 @ 3.6Ghz || GA P55-UD5 || G.skill Ripjaws F3-16000 2000Mhz 2X2GB || Coolermaster ATCS 840 || Silverstone Strider plus 850W || WD 640 black - WD 1TB green - Samsung F3 2TB || MSI 5670 1GB Cyclone ||Coolermaster Hyper 212 + ||
Old August 12, 2010, 09:31 PM
man, that looks good. so the best low profile is this guy right now? killer!
Old August 12, 2010, 10:20 PM
Sushi Warrior's Avatar
Hard to tell from the lack of comparison in regards to other low profile coolers, but I would go with no.
Lets be honest here, I just read the review and felt I found out nothing about it because the closest comparison is the stock intel cooler and that has a loud fan. Where are all the other low profile/small coolers?
You're half way through some post and you realize it's from some retard who types like he's got an array of dog dicks for fingers
Old August 12, 2010, 10:32 PM
err,looks good presentation wise not temps wise.
not a lot of mass/s.a.=of course you need some serious cfms, which might make it noisier, which might not make it perfect for a quiet solution :)
Old August 12, 2010, 10:44 PM
Uh, no. Less mass/Surface area = less resistance for low RPM fans = good at low RPM comparatively to high RPMs. It is better, compared to itself, at low end when compared to high end I would think (less temp drop/RPM than the average cooler).
Old August 13, 2010, 05:19 AM
SKYMTL's Avatar
Please define "all the others".
Also, we have to start somewhere so there will always be one product that may not "fit" until we have others to compare it to.
Old August 13, 2010, 05:55 AM
Varroa's Avatar
It would be interesting to see how it compares to something like this (Scythe Shuriken 3) which I already use in my SFF HTPC:
NCIX.com - Buy Scythe Shuriken 3 Heatpipe Low Profile CPU Heatsink LGA1366 1156 775 AM2+ AM3 939 940 W/100MM Fan - SCSK-1100 In Canada.
GAMER: Win7 Pro x64, I7 3770 (stock) (CM 212+), Asus P8Z77-V Pro, XFX 6950 2GB, Corsair Vengeance LP 4 x 4GB DDR3 1600Mhz, Crucial M4 120 GB + 256GB, Intel X25-M 160GB, 1TB WD Blk, DVD, BRD, HX750W, Auz X-Fi Prelude, Intel Pro CT Gbit NIC & CM Cosmos
Game Server: Win7 Pro x64, AMD Phenom II X4 960T Zosma, Gigabyte GA-MA770-UD3, 2x2GB Gskill DDRII 1000, 640GB WD Blk, 1 ODD, Asus 9600 GSO, Intel Pro PT Gbit, Corsair 400W PS & Antec 300.
Old August 13, 2010, 07:16 AM
You could compare it to 92mm tower coolers and pretty much anything other than 120mm towers. Anything at all smaller than a 120mm tower I guess ;)
Old August 13, 2010, 07:49 AM
AkG's Avatar
AkG AkG is offline
Hardware Canucks Reviewer
We would love to test it against others. But there has to be a FIRST. This is it. If other manufacturers chose to send us more HTPC orientated coolers expect to see them compared against the Sam 17. Prolimatech with its choice of name makes this cooler out to be a giant killer, so NOT including our regular coolers would have been giving Prolimatech's marketing department a free pass on this issue. That would be doing a disservice to you our readers. Comparing it to 92mm coolers is also not fair as this IS a 120mm cooler.
I use a horizontal mounting orientation for all CPU cooling solutions as that is a worse case scenario and allows an apples to apples comparison.
Prolimatech Armageddon CPU Cooler Review Comment Thread SKYMTL Air Cooling 11 June 11, 2010 11:18 AM
Cooler Master Hyper 212 Plus CPU Cooler Review Comment Thread AkG Air Cooling 268 April 16, 2010 03:23 PM
Prolimatech Megahalems CPU Cooler Review Comment Thread AkG Air Cooling 24 June 16, 2009 12:07 AM
Cooler Master Hyper N520 CPU Cooler Review Comment Thread AkG Air Cooling 3 June 8, 2009 07:54 PM
