Old August 10, 2010, 03:10 AM
Default gpu remove thermal paste
Hi
Excuse me but I need you help me for removing thermal paste from GPU and ram. I want to install a Dissipator on my asus 8800gt graphic card
For the ram I can use a a pensil eraser And It is ok.
For the GPU someone tell me that I can use Alcohol for cleaning home and others tell me that I have to use only a dry cotton cloth and plastic phonecard.
I do not want buy expansive specific liquid as akasa or artic cooling cleaner but I do not want damage on my gpu
Thank You
Old August 10, 2010, 03:37 AM
first of all, welcome aboard.
secondly, use a q-tip for both, then as pure alcohol as possible. if its a real mess you can 'thow' in a bit of googone, also with the q-tip.
when you install your new cooler, make sure to not apply too much pressure and dont overtighten the screws.
depending on the card, sometimes i put the cooler 'belly up' and then 'lower' the card onto it.
if its a big card, then you do it traditionally
discharge yourself first, always.
use mechanic gloves if you can,helps against zaps
Old August 10, 2010, 05:20 AM
sswilson's Avatar
Yep, purest alcohol you can get your hands on, but instead of a cotton cloth you can always use a coffee filter. Many GPU tims are baked on so you may find that you need to soak the tim for a while in order to soften it up.
I used to recommend aerosol electrical cleaners, but I've recently changed that opinion after having problems with certain types of plastic (cheap vid card cooler shrouds), so now I only suggest using them if you've used the specific product before and know that it won't affect plastics.
Old August 10, 2010, 07:26 AM
fishingfanatic's Avatar
Smile Cases and Cooling
There you have it. Isopropyl 99% is easy to get from a pharmacy(usually). it's also pretty cheap. Be sure to do this in a well ventilated area with no flames or open sources of heat as most solvents are quite flammable.
Old August 10, 2010, 10:16 AM
JD JD is offline
Depends on your area it seems. Some people have a hard time obtaining 99%, and only 70% is on the shelf. Typically if you ask, they probably have some behind the counter though. In my area, 99% can be found on the shelf.
I would assume its harder to find in places where cooking drugs is common.
Old August 10, 2010, 10:52 AM
High concentration isopropanol is not necessary. Even 50% will do the job; you'll just need to use more of it. Get the highest concentration you can but don't be worried if you can't get 99%.
Old August 10, 2010, 11:19 AM
Smoothie's Avatar
I just cleaned off my old 9800 GTX+, the hardest part was taking off the shroud. I just used this Polish Vodka (67%) I had laying around to clean the old paste off. After putting IC Diamond on it I went from 40C idle/66C load to 33C idle/60C load with 90% fan speed. Man there was a lot of furies on that fan shroud lol.
Old August 10, 2010, 02:34 PM
dustin1706's Avatar
Not sure where the OP is from, but if you are in Alberta, you can buy Everclear. 190 proof, AKA 95% alcohol.
Otherwise, isopropyl is your best bet.
+1 for Q-tips
Old August 10, 2010, 02:46 PM
Eldonko's Avatar
Hardware Canucks Reviewer
I use methanol and a shop cloth. $2.50 for a bottle at Home depot. People are so paranoid about cleaning off TIM lol, half the time I just wipe it off.
Old August 10, 2010, 03:01 PM
lowfat's Avatar
That is all I do. Use a shop towel and wipe/polish it off.
Thermal Pad vs. Thermal paste? RainMaker Troubleshooting 2 April 13, 2010 07:13 PM
Thermal Paste killerjay_47 Air Cooling 9 March 15, 2010 02:53 PM
Thermal Paste r0k0 Overclocking, Tweaking and Benchmarking 11 February 15, 2010 10:53 PM
Thermal Paste? Luckk Air Cooling 16 November 24, 2009 07:57 PM
Thermal Paste miggs78 Water Cooling 4 September 10, 2009 07:17 PM
