Old August 8, 2010, 12:22 AM
Default what would be a decent upgrade from the Ven-X?
I'm currently running my i7 with a Venomous-X. I have it running at 1.23V and its idling at 40-44C and while doing 100 runs in LinX got to 82C. I really don't like how high these temps are, and i also hate the Ven-X mounting system, I'm worried its going to crush my socket if i tighten it any more. So what would be a decent upgrade from here?
So far only two i could really find that are within my price range, and that should outperform my Ven-X are: Noctua NH-D14, and a modded H50 with a 240 rad, and a reservoir. But what do you guys think?
Old August 8, 2010, 12:38 AM
Keltron 3030's Avatar
Why not just make a custom loop as opposed to modding an H50, if that's even possible?
FFFFFFFUUUUUUUUUUUU-
Old August 8, 2010, 12:45 AM
It's very possible, (Guide) H50 Replace Tubes and Res Mod. - Overclock.net - Overclocking.net
I plan on doing a custom loop once i have some cash flow, but the modded h50 is in my price range.
Old August 8, 2010, 12:48 AM
lowfat's Avatar
You'll gain maybe 1-2C from moving to a different heatsink. Maybe.
If you aren't happy w/ your air cooling temps maybe it is time to step it up to water.
Mael
Big Lian Li
Forever Alone
Old August 8, 2010, 10:16 AM
Nothing would be a significant upgrade. Your temperatures are also perfectly fine. Stick with the Venomous-X and leave it be.
Old August 8, 2010, 10:30 AM
jcmaz's Avatar
No point on spending money that will net you minimal performance gains (the H50/Noctua cooler). Save the $$ for your future waterloop.
Wise men speak because they have something to say; Fools because they have to say something.
-Plato
Old August 8, 2010, 02:45 PM
JD JD is offline
The Corsair H70 is coming shortly which should offer better performance if you want to go that route.
But as others have said, just invest in a full proper loop. You're probably looking at around $400.
Old August 8, 2010, 09:05 PM
lowfat's Avatar
Definitely don't need to spend that much for a CPU only loop.
Swiftech XT $55
MCR320 $47
MCP350 $55
10 feet of Primoflex $15
Micro-res $20
3 sets of bitspower fittings $12
$204 + taxes.
Mael
Big Lian Li
Forever Alone
Old August 9, 2010, 05:44 AM
what case is this in? what were the ambient temps? what fans are you using on the venemous-x?
Old August 9, 2010, 05:46 AM
Arinoth's Avatar
Are you set up in just a push configuration, or a push-pull configuration. Also what case/case fans do you have and what fans are on then HSF itself as well?
Here I am: here I remain
VGA upgrade from GTX 260 first, or CPU+mobo upgrade first? panzerfan Video Cards 9 April 6, 2010 08:25 PM
Sound Decent himynameis New Builds 8 September 6, 2009 04:59 PM
recommend me a decent printer :) Silvgearx Peripherals 24 June 10, 2009 07:40 AM
Decent Wireless adapter? magictorch Networking 6 April 25, 2009 03:45 PM
Need help picking a decent TV tuner lanken123 Video Cards 0 October 4, 2008 04:45 PM
