Old August 9, 2010, 09:28 AM
Well i did some playing around with it, remounted it, added some pressure with the bracket, moved my shroud, and temps are now down quite a bit, highest it hit was 75 on one core after 100 runs in Linx. But I found some cheap CPU loop parts, and I'm hoping to snag them today :)
By the way, im in push--shroud--hsf--pull with 2 yate loons at 1300rpm :)
Old August 9, 2010, 01:38 PM
JD JD is offline
Originally Posted by lowfat View Post
Definitely don't need to spend that much for a CPU only loop.
Swiftech XT $55
MCR320 $47
MCP350 $55
10 feet of Primoflex $15
Micro-res $20
3 sets of bitspower fittings $12
$204 + taxes.
Depends what the OP wants though. Granted that's a fine start, but there's better (more expensive) choices too
I'd say it's better to start with a higher flow pump and thicker radiator so that down the road you can toss a GPU in without worries.
Old August 9, 2010, 02:05 PM
lowfat's Avatar
Skinnee Labs | Triple Radiator Comparison V2
The only real difference between the MCR320 and other radiators in aesthetics.
MCR320 held my i7 @ 4.2, and HD5970, and a GTX285 2GB all w/ decent temps. He could go w/ an MCP355 for another $10 which likely would be worth it. It (w/ no top) is what I use in my main rig and it works flawlessly. He could spend hundreds more on a loop but chances are the difference in temps are going to be pathetically small.
The Crippled God WIP
Queen of Dreams WIP
Big Lian Li
Complete
Forever Alone Complete
Old August 9, 2010, 02:38 PM
JD JD is offline
...in aesthetics.
That's all that truly matters
(in my case at least)
VGA upgrade from GTX 260 first, or CPU+mobo upgrade first? panzerfan Video Cards 9 April 6, 2010 08:25 PM
Sound Decent himynameis New Builds 8 September 6, 2009 04:59 PM
recommend me a decent printer :) Silvgearx Peripherals 24 June 10, 2009 07:40 AM
Decent Wireless adapter? magictorch Networking 6 April 25, 2009 03:45 PM
Need help picking a decent TV tuner lanken123 Video Cards 0 October 4, 2008 04:45 PM
