Old August 6, 2010, 09:06 PM
Default Arctic Silver 5 and mx-2
Hello, would a mixture of Arctic Silver 5 and MX-2 have any performance on cooling ? I know the quistion sounds nutz ,but ,just wondering if anyone has ever mixed thermal compound with two different brands ,for example ( Arctic Silver 5 and MX-2 ),and had any good or bad experiences with mixing thermal compound ?
Thanks ,
Old August 6, 2010, 09:10 PM
not knowing what the chemically active? perhaps result would be? i wouldnt intentionally try it
Old August 6, 2010, 09:36 PM
Don't mix. Use one or the other.
Old August 8, 2010, 01:53 PM
Thanks , I'll just stay with one compound
Old August 8, 2010, 02:12 PM
Delavan's Avatar
MX-2 is non-conductive, AS5 is...Your pick.
You can find reviews on multiple thermal compounds, the conclusion is: They mostly end up being the same performance wize. OK OK fluctuation of a few degrees that's it. Shin Etsu is apparently great. HWC sells some diamond-based stuff I think, must be good stuff.
Some are thicker than others, some are conductive some are not.
I doubt you'll come up with a better recipe than what's out there.
I like MX2 myself. Spreads easy, no curing time, doesn't conduct electricity...
i5 2500K @ 4.5GHz / NH-U12P / P8P67 DELUXE / 8GB Corsair Vengeance Arctic White 1.35V 1600 / 2 x N560GTX Ti Twin FROZR II OC in SLI (8823 3Dmarks11 P-score)/ Corsair Performance Pro 128GB SSD
Old August 8, 2010, 06:30 PM
AS5 is not conductive. None of the mainstream thermal compounds are.
Old August 8, 2010, 09:41 PM
Shin Etsu is next to impossible to ever get.
The ic7 stuff isn't really popular due to its consistency when being applied.
I like MX-2 but have yet to try MX-3
Old August 8, 2010, 09:45 PM
dustin1706's Avatar
I have been using AS5 in the past, but I have come to prefer MX-2 due to it being thinner. I always buy the 30g tubes
Old August 8, 2010, 10:03 PM
hmm..artic silver did have a compound that was conductive, mustve been #3?
edit. anyone else tried their matrix?
Arctic Silver Incorporated - Matrix
Old August 8, 2010, 10:49 PM
SugarJ's Avatar
I'm on my second tube of MX-3. It picked up a degree or 2 on the MX-2, same workability as far as I remember. It's good stuff.
The Silver Lining Available Now ipaine Gaming 5 September 15, 2010 07:52 AM
Arctic Launches New Brand of Arctic Equipment Peripherals FiXT Press Releases & Tech News 4 June 23, 2010 09:55 PM
Silver Coils Wall86 Water Cooling 13 April 29, 2009 10:55 PM
arctic silver ceramique application and opteron load temps magictorch CPU's and Motherboards 10 July 1, 2007 12:41 PM
