Old July 28, 2010, 10:56 AM
BootlegUsher's Avatar
The part that worried me the most was when they told the reviewer to just fill in the gap with thermal paste like it was glue or something.
Old July 28, 2010, 11:01 AM
0o0 0o0 is offline
Originally Posted by Linus View Post
I guess this explains my poor temp results when I tested it.
Linus, did you get the temperatures for the physx chip, voltage regulators and memory? I would be interested in how well those metal sinks compare to the stock cooler's solution and the AMP's unisink for vrm's and ram :)
gpu-z can monitor a few of those sensors, and I believe everest can too, though I'm not sure if the physx chip has a sensor. Maybe you could use a sensor from a fan controller or something
Old July 28, 2010, 11:09 AM
martin_metal_88's Avatar
I have hard time belive this is true. Many people are using this cooler with 470/480 and it work great. Tt have probably never contact Gelid or he decide to turn it to a sauce he love. If so many people have it working why this one don't work and why Gelid haven't send a new unit ( if the unit is the problem ). Also, he tried a single unit and tell people not to buy it. It's stupid to tell people not to buy it if your is defective. You have to try more then one to have a good methodology if the first is defective. That's one of the many reason I don't read Tweaktown anymore.
Old July 28, 2010, 11:42 AM
Sushi Warrior's Avatar
Could be a manufacturing defect or something, not EVERY product they ship is perfect and that's why there are RMA's.
Old July 28, 2010, 11:49 AM
If you read the entire article, he did get a second sample. And it had the exact same problem.
Old July 28, 2010, 11:53 AM
yea, I read the article, and read a thread on the EVGA forums about people using it with no issues, but majority are 480's... and maybe its ok for the 480, but not the 470s.
Old July 28, 2010, 12:29 PM
This still not explain why you have result like that
This is on Xtremsystem forum, this guy use a GTX470 from MSI and the cooler work fine. Many people got the same result which are dead good.
http://img832.imageshack.us/img832/7530/capture4x.png
Here is another member Using a EVGA 470 ( same used in the review from TT )
http://content.screencast.com/users/...07-22_1550.png
Look at this entire thread.
Gelid Icy Vision - techPowerUp! Forums
But well, it's not usefull to argue here. We should ask someone here with a 470 to order one and see how it does. I would order one but am using a 260. But the blue UV fan would fit my Blue UV watercool for sure:P
Disappointing XFX RMA experience Vhlad Video Cards 31 December 23, 2009 06:44 PM
GELID Launches Tranquillo CPU Cooler Soultribunal Press Releases & Tech News 3 November 4, 2009 07:10 AM
GELID Fans JD Member Reviews 25 May 6, 2009 08:40 AM
