Old July 24, 2010, 10:17 AM
AkG's Avatar
AkG AkG is offline
Hardware Canucks Reviewer
Yes there is such an animal. BUT its called a BIG arsed fan.
You can get high air flow 80mm fans. You can get low noise 80mm fans. But you cant have both.
Old July 24, 2010, 10:41 AM
Slik's Avatar
O.K. I know what I have to do. Find a happy medium. Thanks all.
EVGA DG 87 -i7 5930k @ 4.4ghz. Liquid cooled-4x4gb G Skill Trident X DDR3@ 2400mhz- EVGA x 2 1080 Ti Black SLI - Soundblaster X7 Sound Card- LG 34" Monitor-ATH AG1X Headphones-Butt Kicker Gamer-TrackIR 5
Old July 24, 2010, 12:32 PM
m4Dm4xx's Avatar
I have this on my HR-03gt NCIX.com - Buy Scythe Gentle Typhoon 92MM Case Fan 2650RPM 26DB 41.7CFM - D0925C12B3AP-14 In Canada. move's a good amount of air and is damn near silent
Old July 30, 2010, 05:05 PM
I have these and they are amazing. Quiet and moves quite a bit of air. I don't recommend using them on a case window; I tried them on a Cooler Master Storm Scout and I could hear the turbulence (but not the front intake, rear exhaust or CPU heatsink).
Old July 30, 2010, 06:29 PM
Originally Posted by m4Dm4xx View Post
I have a few Scythe's in my case and they are damn near silent
I love negative case pressure! More air out than in....
Is it better to have negative pressure in a case then? Or positive pressure?
Old August 1, 2010, 10:38 AM
m4Dm4xx's Avatar
I preffer negative, less dust and better cooling IMHO
Old August 1, 2010, 06:09 PM
Positive pressure is better in general.
Old August 1, 2010, 06:32 PM
martin_metal_88's Avatar
Have to agree once more with zero. The more fresh air you have in, the cooler it is. And don't worry if you have more intake the air will find a way out easely.
  #19 (permalink)
Old August 3, 2010, 10:57 AM
m4Dm4xx's Avatar
I have always ran negative pressure "design's" and in MY scenarios they always performed better than the same build using positive pressure. A google search reveal's mixed feeling's about which is best but i know what has worked better for me in my build's. The choice is your's and it isn't hard to switch a few fan's around and find out for yourself
Thin exhaust fan? Slik Air Cooling 5 November 6, 2009 06:26 AM
How do I wire the exhaust fan to a slower speed? Shadowmeph Air Cooling 8 April 25, 2009 02:56 PM
Is rear exhaust fan really needed? aviduser Cases 18 March 27, 2009 11:49 AM
MM Horizon Exhaust Fans Question zlojack Water Cooling 5 March 2, 2009 10:13 AM
