Old July 19, 2010, 08:13 PM
SKYMTL's Avatar
HardwareCanuck Review Editor
Default Thermaltake Frio CPU Cooler Review Comment Thread
Thermaltake was one of the first companies to release a high-end CPU cooler but in recent years they have struggled to find their stride. The Frio is their latest foray into the heatsink market which retails for under $60 but is supposed to bring Thermaltake's name into line with other industry luminaries like Thermalright and Prolimatech. Can this simple cooler live up to such lofty expectations?
[ Read full article ]
Old July 19, 2010, 08:36 PM
Another great review AkG, thanks for the detailed review.
Wow this thing cleans house, even tops out Prolimatech.. Impressive..
Old July 19, 2010, 08:44 PM
by the gods its indeed a munsta!!!
and its only twice as expensive as the 212+ judging by the cost/perf chart !!!
edit : some say this guy is the top dog atm SP984B1-V2-TherMax Eclipse II™
Old July 19, 2010, 09:07 PM
Oooh, this could warrant an upgrade from my 212
Old July 19, 2010, 10:24 PM
BootlegUsher's Avatar
I didn't follow what you meant when comparing the various fans when you said that it blew away the Noctua. Do you mean that when both fans are spinning at 1300 RPM, that this Frio fan is pushing more air and with less noise? If that is the case then I think I will be buying these fans.
Old July 20, 2010, 01:36 AM
Jamula66's Avatar
When you do open up the top flap and look inside you actually cant see all that much. This is for the simple reason that Thermalright opted for a two part low density foam protection scheme.
When did we switch to a thermalright review???
Old July 20, 2010, 05:38 AM
SKYMTL's Avatar
In those charts, "Thermaltake Frio" = Frio + Noctua.
Old July 20, 2010, 06:49 AM
gingerbee's Avatar
wow thermaltake i am impressed. thermaltake guys really needed this this cooler
Old July 20, 2010, 07:51 AM
sswilson's Avatar
All of that for around $60??? That's impressive.
Can't say I like the look (how did somebody manage to figure out how to add more plastic to a tower cooler!?!?!?!? ;) ), but at that price / performance ratio (plus the inclusion of two fans vice one) I can be convinced to look the other way.... ;)
As far as the rheostats go..... how long is the cable attaching them, and does it look like there would be any way to securely mount the shaft if a person were to drill out two holes in the back of a blanking plate for rear external access to the dials?
Old July 20, 2010, 07:53 AM
AkG's Avatar
AkG AkG is offline
Hardware Canucks Reviewer
The reheostat cables are VERY short. But they attach via a simple two pin connector. So you can yank them or replace their cable with nice long cables if you have the time and patience.
Review Thermaltake Frio - incredible CPU cooler Hgi Reviews & Articles from the Web 5 August 25, 2010 03:01 AM
Cooler Master Hyper 212 Plus CPU Cooler Review Comment Thread AkG Air Cooling 268 April 16, 2010 03:23 PM
Cooler Master Hyper N520 CPU Cooler Review Comment Thread AkG Air Cooling 3 June 8, 2009 07:54 PM
Thermaltake DuOrb CPU Cooler Review comment thread AkG Air Cooling 0 May 21, 2008 08:23 AM
