Old July 20, 2010, 09:00 AM
martin_metal_88's Avatar
Damn, it was about time for TT to give us a good product...it's years now that TT is off the game in almost EVERY field. Will this last?? Maybe. The frio is mid looking for me I prefer clean look bu the fact that you can just remove the top is really nice I like that. I would have get it if I was not under WC now. Can this fit in some HTPC case??
Old July 20, 2010, 09:31 PM
Dark-Colonel's Avatar
Excellent review! I'm still running my stock Intel cooler on my i7 and I think I should upgrade soon because the noise is bothersome while playing, I haven't OC'd yet which is probably why I've been procrastinating a cooler purchase.
Just a question, based on your thoughts, what would you guys go for? The Titan Fenrir or the Frio? They're both very similar and are priced the same.
Also, some spelling errors:
Conclusion, 2nd paragraph, 2nd sentence "The cutting edge construction coupled with extremely versatile fans means that it was able to put forth impressive results in nearly every single test we performance"
should say "performed"
Also on page three, near the middle it says "ou get a small tube of TIM, an instruction pamphlet, mounting hardware for Intel 775, 1156 and1366 systems along with AMD systems"
There should be a space. Not a spelling mistake but probably just very tired fingers and eyes after some long benchmarking :)
Heatware
[ 72 - 0 - 0 ]
Old July 20, 2010, 09:56 PM
if this fits and youre aware that a half blind man can hook it up? no brainer herr colonel :)
btw, if you fix the stock cooler around 60%, is it still irritating?
Old July 26, 2010, 04:03 PM
Seems to be a pretty good improvement over my Hyper 212+. My temps have dropped about 10C on load, 8C idle. I'm also using different fans though.
Review Thermaltake Frio - incredible CPU cooler Hgi Reviews & Articles from the Web 5 August 25, 2010 03:01 AM
Cooler Master Hyper 212 Plus CPU Cooler Review Comment Thread AkG Air Cooling 268 April 16, 2010 03:23 PM
Cooler Master Hyper N520 CPU Cooler Review Comment Thread AkG Air Cooling 3 June 8, 2009 07:54 PM
Thermaltake DuOrb CPU Cooler Review comment thread AkG Air Cooling 0 May 21, 2008 08:23 AM
