-   Air Cooling (http://www.hardwarecanucks.com/forum/air-cooling/)
-   -   Best blue LED fan (http://www.hardwarecanucks.com/forum/air-cooling/34337-best-blue-led-fan.html)
QuantumNerd July 18, 2010 01:50 PM
Best blue LED fan
Any ideas on good blue LED fans?
Right now the big players seem to be the Yate Loon D12BL-12-UB fans, and the CoolerMaster R4 fans. The Gelid Wing 12 PL fans look good too, it's just a shame they're nowhere to be found in Canada.
Lpfan4ever July 18, 2010 03:48 PM
What's good to you? Quiet? Lots of air? Both?
The R4 offers the most amount of airflow out of those three, but is probably the loudest. Gelids are pretty quiet, but I don't know what they're like for airflow (I only have an 80mm one). As for the Yate Loon, I can't comment on that as I've never seen one in real life. However, my Red/Black ones from NCIX are pretty balanced for air flow/noise.
Zero82z July 18, 2010 04:12 PM
I would say Gelid>Coolermaster>>>Yate Loon.
Spikemaul July 18, 2010 06:10 PM
I just bought four CM R4's and they push alot of air. The only other blue LED fan that I have to compare them to is the Enermax Apollish. http://www.enermaxusa.com/catalog/pr...2315e2a50340c2
These fans look very nice and they are not as loud as the R4's but they don't even push as much air as my 5YR old when he farts. :shok: That being said the R4's are not very loud at all and I can't hear any of them over my GTX 275's fan @ 60%.
AmuseMe July 18, 2010 09:35 PM
The apolish fans dont move air at all...there just bling bling
Smoothie July 19, 2010 10:20 AM
Enermax Apollish Vega's ones move a lot more air. Rated at 800-2000 RPM with a air flow of 56.51-143.72.
Here is a link to a blue 120mm one: http://www.enermaxusa.com/catalog/pr...688b61e6c3e14d
kendallcschm July 19, 2010 12:18 PM
Newegg.com - ENERMAX Apollish UCAP12-BL 120mm Case Fan
71 CFM ain't bad... but i think they are ugly... rather use by regular black fan and get 91 CFM
jcmaz July 19, 2010 01:29 PM
The Yate Loons are OK. Not too loud but they don't really move a lot of air. The LEDs are bright, like the ones in the Antec 1200 pics. Just a note tho, i would get better screws coz the ones Yate Loon gives you are absolute crap. They strip easily.
