Well, I NEED some of that Tape, NCIX is looking into it. Getting some tape for free would be an acceptable way to get out of that RMA situation.
On top of that, I bought nylon nuts & bolts (needless to say they're small), to re-install the factory back plate on the card, to prevent it from sagging. Nylon being non-conductive, It's ok.
I won't OC the card, so the VRM issue MIGHT be a non-issue. I won't run FURMARK either.
It would be nice to find a stock cooler, take it apart, take the plate off it, and sandwich the PCB between the stock cooler plate( good at cooling VRMs) and the backplate...it could be challenging to do, and even more challenging to find a second-hand stock cooler for cheap. Maybe it's not worth it.
I should of bought a Vapor-X and call it quits...
Something like that:
Google Image Result for http://www.overclock.net/attachments/ati-cooling/144924d1267935970-aftermarket-cooling-solutions-ati-hd-5850-dsc00449.jpg
Oh, I don't know I might just sell the darn cooler, it's still in the package...I guess this Fall/Winter (with lower room temps) might just do it for now and drop the temps a few extra degrees...and I'll pass the card on to my little one next year and get what 's new.
But I swear the god, with CAT10.5 I had lower temps!
