Originally Posted by tragd no, my question was how to remove the fan clips from the fans, rather than removing the fans from the heatsink.
not sure if it is possible. |
are you talking about the wire metal thingy that holds the fan to the heatsink itself?
I found them to be very tricky to remove, and just as frustrating to replace... just keep fiddling with them.
I would describe to you how I removed mine, but I honestly do not quite remember, and I cannot try again because they're in my case ATM.
