Originally Posted by LaughingCrow Probably easier to just replace it with a quality fan.
Does the fan have ball bearings or a sleeve bushing?
Are the blades dusty? or any of the fan blades damaged or bent?
Is it a variable speed fan connected to the motherboard (3 or 4 pin) or just single speed connected via a Molex connector?
WD40 is not the best of lubricants - the WD stands for Water Displacement. It's quite 'thin', more like a solvent than a dedicated lubricant. Don't use any graphite based lubricants either - graphite is conductive. If you're intent on lubricating it, try a 'fine' lubricant like a sewing machine oil or fishing reel oil. |
You know way too much about lubricants....
Yeah I'd just replace the fan myself though. When they go, they go. Its usually not worth the hassle of reviving them because when they are on the way out, there is little you can do.
ST
