Old June 23, 2010, 07:39 PM
geokilla's Avatar
Default Help Installing Cooler Master Hyper 212+
How in the world do you install it? I've been struggling for an hour! I'm following the user manual and Cooler Master Hyper 212 Plus CPU Cooler Review too but ugh.
Old June 23, 2010, 07:50 PM
Lpfan4ever's Avatar
HWC has you covered.
Originally Posted by encorp
Code:
<firebane> slightly used
Old June 23, 2010, 07:57 PM
chrisk's Avatar
Folding Captain
Make sure you put some TIM in the grooves of the base. If you do the normal 'pea sized amount' much of the TIM ends up in the grooves and you don't get a spread.
I put some TIM on my finger (my finger was inside a plastic bag making it a kind of glove) and put some in the grooves.
Other folks have put small lines of TIM on the base/heatpipes, and others put some TIM on the CPU and spread it with a credit card.
Also;
1. Backplate on first. There are some screws taht allow you to mount it.
2. There is a thumb-screw in the middle of the plate, under the fins. Turn it to tighten the base to the cpu.
Fold for team #54196
geokilla's Avatar
That's what I used... but it didn't help.
Anyways, I finally got it >.> Took a while.
I put 3 lines of AS5 in the middle of the HDT where the aluminimum stuff is. I think that's enough. That's how I installed the Vendetta 2.
Old June 23, 2010, 09:43 PM
Haha...funny how i forgot to do that in one of my earlier installs. Thankfully I swaped the cpu within a week and noticed.
Temperatures for AMD X4 940 at stock speed using CM Hyper 212+ cooler p3t3r1 Overclocking, Tweaking and Benchmarking 37 June 30, 2010 08:36 PM
OCZ Vendetta 2 vs Noctua NH-U12P SE2 vs Cooler Master Hyper 212+ geokilla Air Cooling 13 June 21, 2010 03:45 PM
Cooler Master Hyper 212 Plus CPU Cooler Review Comment Thread AkG Air Cooling 268 April 16, 2010 03:23 PM
Cooler Master Hyper N520 CPU Cooler Review Comment Thread AkG Air Cooling 3 June 8, 2009 07:54 PM
