Hi,
I just replaced the fan on my Xigmatek S1283 Dark Knight/w back plate (2000 rpm, 120mm fan) that was getting noisy.
I picked the Noctua P12, for it's ability to create more static pressure than most fans. I'm not impressed, I guess my expectations were too high.
I also think HWC already benchmarked that config in a Xigmatek review back in the day.
The fan is really silent, but i got a raise in temperature!!! A good 3 degrees celsius increase in temps!!!
The Xig is not officially supporting push-pull, so i might have to "tie-down" another 120mm fan (ghetto style).
OR pull the nasty 1 inch thick Panaflo 120mm fan out of the parts bin...OUCH...effective but noisy!!!
I'll try to reseat the HSF, use new MX-2 thermal paste, I'll try the "lips method"
http://benchmarkreviews.com/index.ph...1&limitstart=5
I think AKG got good results with it in reviews...
I'll be moving my config from the Antec 300 to the ATCS840 tomorrow, at least I'll have more room to work with inside...
My question: As my HSF's fan is pushing air horizontally towards the back of the case (I thought it was the only way for HDT coolers) could it be better to mount it blowing upwards?
