So knowing that warmer weather would soon be here and after adding a water cooled GTX480 to my single loop, I decided to experiment with a higher rpm fan for my triple rad. So I figured I would grab one to start and see how it did.
The Delta I wanted was out of stock, so I switched to this one:
Delta 120MMX38MM Fan Dual Ball Bearing 3900RPM 148.34CFM 51DBA 4PIN PWM
Problem is, I can't figure out how I'm gonna plug the darn thing in, just to see how loud/effective it is. It is only wired with a 4-pin. So I don't want to plug it into a mobo header, and my fan controller (NZXT Sentry2) which it would most likely melt, only has 3-pin connectors anyways. I have a dozen 3-pin to molex adapters, but that doesn't help. Even the higher wattage rated fan controllers seem to only use 3-pin connectors.
Perhaps there's an obvious solution (other than not to get the fan!), but i'm not seeing it. Any help would be appreciated
