Old June 14, 2010, 10:48 PM
CroSsFiRe2009's Avatar
Hyper 212+ uses a backplate. Not many aftermarket heatsinks these days use pushpins. Even scythe seems to have stopped using them that much.Also, don't spend so much on expensive cooling if you aren't going to be overclocking much. It'd only be a waste of money.
Old June 15, 2010, 02:03 AM
Arcnor's Avatar
Lightbulb Fenrir?
I appreciate that the Megahalems is a pretty high-end cooler. I haven't thrown any money out into the world yet, and I'm willing to pay a little extra for nifty looks and no-worries performance, but it's true that I won't be doing any insane overclocking, not for a while anyway, until I get my bearings. I wouldn't mind having the capability, but it probably would end up being wasted to a degree.
I took another look at the Titan Fenrir -- the noise issue turned me off it at first, but that's apparently only an issue when its fan is running full-blast, and that's probably true of most any high-performance fan anyway. Seems like it's a lot better behaved at lower speeds, still cools well, and is PWM capable, so I wouldn't have to worry about mucking around with wiring I don't readily understand just yet -- just plug and play. And it's a good deal cheaper, especially considering it comes with a fan, though it looks like I'd have to source it from the states. Oh well, nothing's perfect. If I decide not to be extravagant (and I freely admit that the Megahalems with dual fans would be an unreasonable extravagance given my needs), maybe the Fenrir would be a better bet.
Old June 15, 2010, 07:40 AM
AkG's Avatar
AkG AkG is offline
Hardware Canucks Reviewer
I can honestly say I love the Titan Fenrir. I can also honestly say that the Nirvana is on sweet piece of kit. It uses a backplate setup and comes with a very good fan. It is another good choice. You will lose a bit on cooling....but gain a LOT on the noise profile as its fan is down right quiet...Noctua P12 quiet. ;)
Intel Core i7 / LGA1366 CPU Cooler Roundup
Old June 15, 2010, 10:08 PM
Arcnor's Avatar
Question Nirvana?
I like the Nirvana -- it looks nifty.
Saw a couple reviews in some other dark corners of the web (which shall remain benchmarkreviews.com) that weren't quite so rosy on its performance, so I kinda waffled on it. Plus, I can't seem to find one that's out-of-the-box 1366 compatible -- every Nirvana kit I find needs an additional bracket for 1366 motherboards, and the bracket uses plastic push-pins, which I'm given to understand aren't the greatest and require some force to properly install (given my luck, I'm sure I'd brick something if I push!). So every time I go price-shopping at Newegg or elsewhere, the Nirvana never shows up under 1366 heatsinks. ZeroTherm's website lists the "PWM" version as compatible, but the "Premium" isn't (and I can't find either at Newegg or NCIX -- actually, the only places it seems to pop up are Europe or Australia). What particular kit did HWC review (there are about four different ones floating around)? Seems like it came with all the necessary bits and didn't involve push-pins. If I had that, and could shrug off the (admittedly, only one) bad review (and, by contrast, bit-tech.net did rather like it), I might go for it. It'd certainly take the fan question off my mind, so I could go back to more important stuff like obsessing about whether DDR3 1600 memory will work at its rated speed with a Gigabyte UD5 mobo without any mucking around (but that's another thread -- literally, go look!).
Well, it's shaping up to be either the Nirvana if I can find a kit with all the necessary bits, a Megahalems if I'm feeling too heavily-laden with extra cash, or maybe a Fenrir -- apparently Titan's coming out with a new version called the Fenrir Evo that's supposed to be pretty nifty, though I have no idea if or when it'll be available around these parts.
Thanks for all the patience and advice, AkG. Much appreciated!
Old June 16, 2010, 06:16 AM
AkG's Avatar
AkG AkG is offline
We reviewed the PWM model. It didnt use plastic it had 4 metal tabs w/ spring loaded bolts. No idea on what they ship with now. I know that shortly after that review went live I was states side and picked another one up and it also came with the same hardware...but that has been awhile ;)
For my builds I have a couple coolers that are my "go to" coolers. I know they work, are easy to install and look at the very least decent.
For budget builds: CM 2112+
Set it and forget it. Great numbers at stock loads, good stock fan, great price.
moderate budget builds: Zalman CNPS10X FLEX (not the extreme). Almost as good results at stock loads, but much better at higher loads. Pair it with a Noctua NFP12 for low noise builds, Scythe SFlex E/F/G for more performance orientated builds.
high End: Prolimatech MegaShadow. Looks like a million bucks. Great for high end OCs. OR a Noctua D14. Depends on how much the build budget is and the OC goal. I also like the regular non blackened Prolimatech Megahalem but it really depends on the price dif between them at the time of build and if the case has a side panel window ;)
Any of those will give you good to great results. The Nirvana is a great cooler, same with the Fenrir, but the others I use are "better" for my needs. My basic requirements are: a) easy to FIND b) easy to use c) reasonable price d) be able to mount std 120mm fans e) great performance at a given heat load
IF the Nirvan was easier to find and came with ability to mount ANY 120mm fan it would be on my short list. If the Fenrir was easier to find...it too would be on my short list. Since they are not....I dont go looking for trouble when I know others are just as good or better for my needs ;)
For fans I use are Gelid (silent for cases, wing for occasional cpu cooler build), CM Blademaster (almost impossible to find now, but where great for coolers), Cm R4 for budget to moderate priced builds on coolers or volt modded as case fans, Noctua NFp12 and NFp14 for low noise case and cooler fans. Scythe E/f/g for higher end builds.
YMMV
Old June 16, 2010, 06:43 AM
when spending 'big bucks' on a heatsink, one must not overshadow the importance of the choice, i.e. a great low speed sinkie or a needie high(er) speed one. i see people pair either with the wrong fans and oh the unhappy words afterwards
[FS] Fans, air cooling, heatsink, dvd-rom bigjee Buy/Sell & Trade 27 November 8, 2009 03:05 AM
can dual fan TRUE clear mosfet heatsink on Evga 3x-sli E758? UndeadGhost CPU's and Motherboards 7 October 27, 2009 04:55 PM
[FS] Bunch of stuff (Fans,Video cards, CPU, Heatsink) ddude27 Buy/Sell & Trade 20 May 13, 2009 07:02 PM
How often do I have to replace CPU Heatsink, and Fans? appplejack Air Cooling 8 February 12, 2009 11:48 AM
