Old May 25, 2010, 06:19 PM
Default Another fan... Antec 300?
Well, I purchased a budget case last week which is the Antec 300. I have 2 nice blue led fans in front, one in the back, and one on top. I don't like the heat I'm seeing; it's nothing to worry about. I decided that maybe I should add another fan (on the side). Would putting a fan on the side be a horrible thing for the air flow?
Would you guys recommend any fan? I'm also looking for a fan that will light up blue unless it won't show.
Old May 25, 2010, 06:24 PM
Perineum's Avatar
I use that case all the time in my builds. I use 2 1000RPM fans in the front, and leave the 2 stock ones in the rear and the top. I usually don't put a side fan on. Air *will* go through the side panel anyway though. You'll see the dust build up on it.
[WTB] LOCAL ONLY Antec 300 Case nosebleedXD Buy/Sell & Trade 4 January 31, 2009 11:25 AM
[WTB] Antec 300 (or 900) divertiti Buy/Sell & Trade 3 January 1, 2009 02:35 AM
Antec 300 LEDs BALISTX Cases 1 December 14, 2008 02:05 PM
Antec 300 or CM590? Cptn Vortex Cases 12 September 30, 2008 09:12 PM
P182 vs. Antec 300 Infiniti Cases 11 May 30, 2008 09:48 AM
