  #31 (permalink)
Old October 19, 2010, 05:13 PM
martin_metal_88's Avatar
It will fit inside. But any reason to go with the cosmos S? There is many better case for less money??
  #32 (permalink)
Old October 7, 2011, 01:49 PM
uwish's Avatar
I am running the Ven X RT with my 1090T CPU OC @ 4 Ghz and only 63C. It was easy to mount and all I can say is I am impressed. The included fan in very quiet and I was getting 60C @ 3.2Ghz with stock cooling.
It is a monster though, heavy and large but it fits fine with my Asus M5A99X evo board in a Coolermaster Haf x case.
Very happy with it, got it for under $65 at directcanada.com. NCIX wants over $80 plus shipping.
  #33 (permalink)
Old October 8, 2011, 10:15 AM
Err... I hope you know that AMD Phenom II processors aren't supposed to go past 62C.
  #34 (permalink)
Old October 8, 2011, 04:31 PM
uwish's Avatar
it went over 60C with stock cooling and stock speed (3.2Ghz) so as long as I am under that I am happy. I don't now many people who can get their CPU under 60C @ full load without extreme cooling solutions.
AMD 1090T @ 4Ghz
Thermalright Venomous X RT cooler
AMD M5A99X EVO MB
4GB DDR3 RAM
XFX Radeon 6870
Coolermaster Haf X case
>3 TB storage
dual Samsung 22" widescreens
  #35 (permalink)
Old October 8, 2011, 05:11 PM
AkG's Avatar
AkG AkG is offline
Hardware Canucks Reviewer
The stock AMD cooler is barely adequate at stock performance.
Running your AMD at anything above AMD's 62C recommendation will shorten its life. How MUCH it shortens it is open to debate. What is not is that it WILL shorten the lifespan. You may want to reapply your TIM and re-seat your cooler.
Personally I use 60 as my safe number for AMD rigs.
YMMV
if your opponent has a conscience, then follow Gandhi. But if you enemy has no conscience, like Hitler, then follow Bonhoeffer. - Dr. MLK jr
  #36 (permalink)
Old October 8, 2011, 07:23 PM
uwish's Avatar
i should add, that 63C @ 4 Ghz is under full load, not idle. I am not going to sweat it out over 1 or 2 degrees.
AMD 1090T @ 4Ghz
AMD M5A99X EVO MB
4GB DDR3 RAM
XFX Radeon 6870
>3 TB storage
Thermalright Set to Launch Venomous-X CPU Cooler FiXT Press Releases & Tech News 11 December 15, 2009 07:26 AM
Thermalright Ultra-120 eXtreme 1366 RT CPU Cooler Review Comment Thread 3oh6 Air Cooling 16 January 31, 2009 11:23 PM
Thermalright TRUE Black 120 CPU Cooler Review comment thread freakgeek1337 Air Cooling 17 August 1, 2008 05:16 PM
Comment thread for Thermalright HR-11 Backside Cooler Review SKYMTL Water Cooling 0 September 24, 2007 06:23 AM
