Originally Posted by BobbyLou ^ no mounting pressure
I've own both of these coolers, and I have to say the ven x performs good and is more well sized for ATX motherboard use then the megahalems, but the Megahalems is far superior in terms of build quality and matches if not beats the Ven X, it's just a bit bigger. Anyone agree? Just my 2 cents.. |
I own the Megahalems and have installed the Venomous X for someone else's 1366 build. Although I really like my Meghalems, I find the Venomous X to be better for 1366 builds.(which are usually on ATX boards) It might have to do with the better finish, pointier convex base, and higher mounting pressure. But I'm sure of one thing, my Megahalems took a huge performance hit when I mount it N/S instead of E/W, while the performance hit on the Venomous X didn't seem to be as big. (maybe staggered heatpipes fight gravity better?) But then again it could just be my thermal pasting skills.
EDIT: forgot to add my gripe about the lack of anti vibration accessories on the Meghalems.
