Old May 11, 2010, 05:10 AM
Varroa's Avatar
Default Long shot, need single slot cooler for 3650 AGP
Hey Guys, I have a weird situation on my hands. My wifes rig that I built uses a AM2 CPU and a Powercolor 3650 AGP card. I built it to utilize some of my old AGP cards (at the time) but now I am stuck using this AGP card and the fan is dieing. I have oiled the fan a couple of times but it keeps making noise. The board is a mATX and the PCI slot next to the AGP card is occupied. I don't want to buy another AGP card (for obvious reasons) so are there any decent single slot coolers you would recommend for this strange card? I tried using the HSF from a PCIe 3650 I have but it hits some of the capacitors and I don't think the holes lines up either.
GAMER: Win10 Pro x64, I7 3770K (4.7Ghz) (corsair H110i), Asus P8Z77-V Pro, EVGA GTX 1080 FTW, Gskill 2 x 8 GB DDR3 1600Mhz, Crucial M4 120 GB + 256GB, Crucial M500 480 GB SSD, Mx 500 SSD, HX750W, Sound blaster Z, & Fractal Design Arc MIDI R2
Lenovo Ideapad Y510p: i7-4700MQ 2.4GHz (undervolted by 80mV), 16GB DDR3L-1866MHz, Intel GMA 4600HD / SLI'ed Nvidia Geforce GT 755M 2GB GDDR5, 240 GB Crucial SSD, 128GB M.2 SSD, 15.6" HD+ Glossy LED
Old May 11, 2010, 05:55 AM
Dr_BenD_over's Avatar
Fallen Folder
Is there room on the other side of the card? Maybe something like the TR HR-03 will work, it's not listed but you never know.
All's well that's Haswell
Old May 11, 2010, 06:21 AM
AmuseMe's Avatar
Im not sure if this counts, but you can always get one of those video card fan coolers that fit in a PCI slot. It takes up a single slot, but I'm assuming you want it to stay in the same slot as the 3650.
Old May 11, 2010, 06:50 AM
Varroa's Avatar
Thanks but that won't work since I have the next slot occupied.
The TR HR-03 cost as much as a new video card! Kind of defeats the purpose.
Old May 11, 2010, 06:52 AM
jcmaz's Avatar
How bout the Coolink GFXChilla? If you run it on passive mode (w/out fans) there should be more than enough space for a single slotter.
With the fans, the cooler has about 1mm of clearance to the next pci slot :(
and cooling is compromised (due to stuff blocking airflow)
-Plato
Old May 11, 2010, 07:03 AM
Varroa's Avatar
I'll check that one out, thanks. Otherwise I think I will just remove the fan, leave the heatsink and strap a 120 mm fan on above the card or something.
Old May 11, 2010, 07:05 AM
Fallen Folder
Vantec ? Vantec IceberQ 4 Pro Premium VGA Cooling Kit - CCB-A4P - Premium Copper VGA Cooling Kit with Blue LED Fan
Old May 11, 2010, 08:24 AM
Varroa's Avatar
No mention on that one if it fits a 3650 so I will have to measure the holes to see. It is currently on sale at newegg.ca as well.
[WTB] Long Shot: Lian-Li XB01 case CMetaphor Buy/Sell & Trade 3 May 26, 2009 08:10 AM
[WTB] 9600GT with a single-slot cooler Dead Things Buy/Sell & Trade 19 April 15, 2009 10:00 AM
[WTB] A very LONG shot! Mike_E Buy/Sell & Trade 13 February 17, 2009 07:04 AM
Single-slot coolers S_G Video Cards 1 October 25, 2008 03:15 AM
WTB HD2600 or 3650 512MB AGP vulcan500rider Buy/Sell & Trade 4 April 21, 2008 07:42 AM
