Old May 9, 2010, 12:55 AM
Default fan choices
whats the best fan choices for radiators and for intakes into a tight case would i be better off with alot of cfm or static pressure?
Old May 9, 2010, 04:45 AM
Soultribunal's Avatar
Anything that goes on a Radiator, or Heatsink with dense fins needs a good static pressure rating.
For LED Fans the Coolermaster R4 LED's are a very good choice as they have an excellent static pressure rating.
Beyond that the SilenX iXtreme fans are not bad either, nor are the Gelid Wing 12 series.
Regards,
ST
www.realhardwarereviews.com
Old May 9, 2010, 07:40 PM
JD JD is offline
Gentle Typhoons are probably your best bet IMO. San Ace's are nice too but hard to find and require a fan controller unless you enjoy noise. Scythe S-FLEX's are pretty decent too. And there's always the cheap Yate Loons.
I'd avoid anything SilenX though. They aren't typically suggested for anything really.
Old May 9, 2010, 08:35 PM
AkG's Avatar
AkG AkG is offline
Hardware Canucks Reviewer
For rads and cpu coolers, static pressure > CFM. You can have all the air movemnt in the world when there is no backpressure BUT if it cant push past the resistance the CFM will tank, whereas a high static pressure fan will be closer to its cfm rating even under less then ideal conditions. This is why I like CM R4s, Scythe S Flex and Noctua fans. If you dont mind going thicker 120x38mm fans are usually higher then 120x25mm. I like undervolted Panaflo's and San Aces...but they are expensive.
For case fans, cfm can be more important then static pressure BUT it depends on the case and the design of the fan ports. Lower quality cases have less then optimal holes for the fan, which in turn make the fan fight for every breath of air it can get. All in all, Cm R4s are a good choice for higher demand cases (for good cases it doesnt really matter to much, get a good CFM low noise fan like Gelid Wings and you will be laughing). You can volt mod them down to make them quiet, yet they will still have kick ass static pressure and still move a decent amount of air. Another good choice is Yate Loons. But once again you will have to volt mod some of them as they are loud at 12v but silent at 7v.
Old May 9, 2010, 08:45 PM
ive been looking at all your guys sugestions and ive noticed no one really likes the silentx xtrema fans.
they have the highest cfm to dba ratio that ive found (70cfm to 20dba roughly) i was thinking use them for my intake fans.
no good? if so why not.
thanks
Old May 9, 2010, 09:51 PM
jcmaz's Avatar
Never trust manufacturer's dba ratings. They are almost always off.
-Plato
Old May 10, 2010, 07:58 AM
JD JD is offline
thanks
Precisely. SilenX is known to lie the most about their ratings. I don't think Coolermaster is much better either with their ratings (90CFM @ 19dBA, yeah right). From what I recall, Scythe and Noctua are pretty honest about things.
Old May 10, 2010, 08:16 AM
CMetaphor's Avatar
Quadfather
I've said it before and I'll say it again: You're looking at two different ratings there. Its not "90CFM @ 20db" or "70CFM @ 14db" but in fact it's saying "As much as 90cfm at max, as quiet as 20db at minimum". That being said, the R4s a dam good any way you look at them.
Old May 10, 2010, 09:07 AM
martin_metal_88's Avatar
If you are looking for silence on your rad then Scythe gentle typhoon 1450 RPM are probably some of the best. They have a pretty high air flow and are dead silent ( but a bit heavy ) so you NEED a backplate ( bolt-thrue kit ) on your cooler. Coolermaster R4 are also nice but they are 2000RPM so a bit noisy. You can also take a loot at Yate loon ( the red one ) I can't remember the model number. For intake, then you don't need to have a killer pressure or high airflow. Only decent will be enough. Gelid wing 1000RPM are seriously fine, lower speed r4 are also a must have. For intake I also like Zalman something f3. They come with a little res that alow you to cut the speed so they are silent, realiable, good price and move a good amount of air for a intake fan. Hope you get everything you need here!
Old May 10, 2010, 05:49 PM
im looking at the r4's at ncix and they dont have them in red or non led black. they gotta be either red or black otherwise my case is gonna look dumb. so i guess im going with the sythe gentle typhoons for the rads and... actually ncix doesnt even have those.. were do you guys get your fans from?
X58....too many choices.... lowfat CPU's and Motherboards 20 April 6, 2009 05:03 AM
Motherboard choices. SiDiX007 CPU's and Motherboards 8 August 23, 2008 02:46 PM
Too many choices! Need advice! majingrim New Builds 7 August 13, 2008 04:29 PM
2 choices belgolas Video Cards 9 December 9, 2007 06:53 AM
Lian-Li, too many choices... Cardboard box with DSL Cases 10 September 27, 2007 08:33 PM
