Old May 9, 2010, 12:28 AM
Default i wanna paint my fans
im buying 13x 120mm and 4x 140mm noctuas but i want to spray paint them all black. bad idea? will it throw off the balance of the fans and make them more turbulant and noisy? or will they be alright.
thanks
Old May 9, 2010, 12:35 AM
encorp's Avatar
It won't work unless you buy vinyl or plastic bonding paint. Krylon makes decent stuff.
It's doable.. It will somewhat effect performance but not by all that much.. they'll be fine. Google guides on painting fans... Your best bet is to dismantle them first.
Really though if you don't like the colour of Noctua's just go buy an equally performing fan in a different colour :)
DISCLAIMER: The views and opinions expressed in the immediately preceding post are those of encorp and do not reflect the views and/or opinions of family, friends, or anyone remotely associated with encorp unless explicitly stated. encorp does not make any warranty, express or implied, or assumes any liability or responsibility for the quality, factuality or use of information in the immediately preceding post.
Old May 9, 2010, 11:45 AM
Jackquelegs's Avatar
If you don't get it exactly balanced, the fan will become INSANELY off balance, and literally unusable.
Hence it's important to get a light and even coat
Iapetos
Zephyranthes
Old May 9, 2010, 07:38 PM
JD JD is offline
I used some Duplicolor vinyl dye from Canadian Tire on my Noctua P12s. Didn't seem to have any ill effects and the fans are running in my server 24/7 currently.
I broke one of them though just by dropping it off my table. Blades poped out and I guess all the lubricant leaked out, since now it makes quite a bit of noise.
Old May 31, 2010, 12:06 AM
Noctua's are so pretty... I can't see why you would want to spray paint an artistic masterpiece in design.
Old May 31, 2010, 05:22 AM
stoanee's Avatar
heatware
Wanna see something cool? WolfBane Off Topic 16 February 26, 2009 06:40 PM
Wanna help me gather some things? Lpfan4ever Overclocking, Tweaking and Benchmarking 5 December 7, 2008 11:24 AM
i wanna get my feet wet ebdoradz Water Cooling 29 July 6, 2008 06:48 AM
I wanna go SLI, should I go all in now? erikpilon Video Cards 8 September 22, 2007 08:16 AM
Wanna see GDDR3 vs. GDDR4? Babrbarossa Reviews & Articles from the Web 0 June 4, 2007 11:47 AM
