Originally Posted by Soultribunal All depends on how its done. And the Quality of the Components used.
ST |
as you can tell by the review you guys did, top notch components are always used
Originally Posted by AkG Now THAT looks like a nice LCD. IMHO the only "weakness" of the FC5 was/is the screen.
Its a shame you dropped the max wattage down to 20w. Still should be more then enough for most peoples needs, but all the beefy goodness of the FC5 + the FC6 screen would be one potent combination! |
FC6 is the cheaper alternative to the FC5, FC5 will still be sold for quite a while you have no fear of that, and when revision 2 of the FC5 comes, the LCD problems will be corrected.
