Old April 21, 2010, 05:22 PM
ZZLEE's Avatar
Default Fractal designe Fan splitter one 4 PIN to 16 Conectors
NCIX.com - Buy Fractal Design PCI-MOUNTED Fan Power Splitter - Converts One 4PIN Molex to 16 Connectors - 5321185 In Canada.
Looks interesting under 20$ and in pre order
"EVGA hunted down the last dozen or so expats living in Karachi." SKY
Old April 21, 2010, 06:35 PM
cool but how do you control the rpms? actually...hmm...uou can hook that one molex in with some do it yourself...hmmmm
Old April 21, 2010, 08:05 PM
MpG's Avatar
MpG MpG is offline
From the picture, it looks like those voltage regulators give you the choice of several voltage settings, but the voltage is set at a predetermined level for each plug, so you probably can't run them all at one level. And no fan rpm feedback, obviously. And since they have the tab for the card socket, this probably wouldn't fit into a PCI-E slot.
Old April 21, 2010, 08:14 PM
SugarJ's Avatar
They have stepped power outlets, similar to this Bitspower, which has 12V, 7V and 5V 3pin plugs. NCIX.com - Buy Bitspower X-STATION POWER-EXTENSION I - Male Version 4PIN Molex to Power Distribution Board - Green - BP10500 In Canada.
Old April 21, 2010, 10:37 PM
MpG's Avatar
MpG MpG is offline
Well, technically, that BP unit is just giving the 5V and 12V right out of the molex, and crossing the two to give 7V, which not everybody is entirely at ease with. This unit looks like it actually pulls the voltage down via regulator, which eliminates that issue, albeit with a little bit of heat to contend with (which shouldn't be an issue when mounted in an expansion slot).
Tags
1 to 16 , fan splitter , fractal design , molex
[WTB] (GVR) 3 pin Y Fan Splitter & RAM Sinks jcmaz Buy/Sell & Trade 3 April 21, 2010 04:17 PM
CPU Fan Splitter Plug FreeKnight Air Cooling 5 February 8, 2010 09:53 AM
Fan Controller : Can you use a Splitter? BobbyLou Air Cooling 5 December 8, 2009 11:57 AM
Make a 3 Pin fan run without a PSU BobbyLou Troubleshooting 8 July 29, 2009 05:29 AM
3 Pin to 4 Pin Fan Plug Adaptor? Thund3rball Video Cards 6 March 25, 2008 01:46 PM
