Old April 18, 2010, 02:22 PM
Default Small and silent cooling options?
So I just recently installed an Arctic Cooler 7 Pro in my C2D build (ATX case), this was my first step into aftermarket cooling. I loved how it was basically silent (probably due to the huge fan)
Now looking at my AMD Athlon II X2 build, I'm still using stock HSF, but am probably limited in choices. It's my HTPC and it doesn't have much headroom, even with the stock HSF. I was wondering if anyone had any ideas of small HSF's that are silent, but effective.
Any comments would be appreciated :)
Here are pics of the current situation:
New on HWC but lots of feedback on RFD (89-0-0)
XBMC Rig (1900PPD): AMD Athlon II X2 240 @ 3.2ghz | Gigabyte GA-MA78LM-S2H | G.Skill 2GB DDR2 800 | WD Caviar Blue 500GB | Antec NSK1300 SFF Case
Folding Rig: (1700+4500PPD) Intel Core 2 Duo E6600 | Gigabyte GA-P35-DS3L | OCZ Special Ops 2GB DDR2 800 | EVGA 9800GT | G.Skill Falcon 64GB SSD | Samsung Spinpoint 1TB | Seagate Momentus 1TB | Generic ATX 430W Case
Old April 18, 2010, 02:31 PM
rapmaster's Avatar
I don't know if it will fit, but here a suggestion :
NCIX.com - Buy Scythe Shuriken 3 Heatpipe Low Profile CPU Heatsink LGA1366 1156 775 AM2+ AM3 939 940 W/100MM Fan - SCSK-1100 In Canada.
Old April 18, 2010, 03:47 PM
Zalman CNPS8700
Zalman CNPS7500-CU
The 8700 is a newer model, thus including a heatpipe. The 7500 is older, but more than enough for a dual core A2X2.
Both of them are 67mm tall and should fit. Case looks like an Aria.
Old April 18, 2010, 03:59 PM
Originally Posted by ayah View Post
Zalman CNPS8700
Zalman CNPS7500-CU
Cool, thanks guys, do you know if these are quieter fans than the scythe?
Also, my case is an Antec NSK1300
Old April 18, 2010, 04:01 PM
Originally Posted by rapmaster View Post
+1 for these. great short(well wide but not tall) coolers
Old April 18, 2010, 07:25 PM
TopDogZero's Avatar
Since you like the Arctic Cooler Freezer 7 Pro you could check out there other low profile coolers here Arctic Cooling
No heatpipes but they uses the the same fan as the Freezer 7 Pro and from the looks of your photo you don't have a lot of room to spare because of the power supply.
RMA: What are my options? Gaston Troubleshooting 7 March 22, 2010 12:34 AM
Passive cooling/silent cooling Cowboy Air Cooling 9 September 17, 2009 11:38 AM
Upgrade Options... Infiniti Off Topic 4 May 13, 2008 07:07 PM
Best C2D Air cooling....(non silent) keenan CPU's and Motherboards 20 August 14, 2007 05:53 PM
Options.... if any? 3.0charlie O/S's, Drivers & General Software 16 July 8, 2007 10:20 AM
