Old April 17, 2010, 02:11 PM
Musabi's Avatar
Default Speedfan?
I am trying to find a way to change my fan settings via software. Is there a way to do this with speedfan or should I just get a can controller?
Old April 17, 2010, 02:27 PM
if speedfan works, good. you may want to try auto,manual or whatever else setting in the bios to get it to work. sometimes the mobo manufacturer has a program for it.
Old April 17, 2010, 02:34 PM
best thing to do is try :P
Old April 17, 2010, 03:16 PM
Musabi's Avatar
I was trying in speedfan but it doesnt look like its doing anything for me sadly =\
Old April 17, 2010, 04:39 PM
TimTheEnchanter's Avatar
Worked for me but can't make it lower fan speeds at startup, which kinda makes it useless for the usage i need.
Old April 17, 2010, 07:21 PM
I personnally can't do without speedfan. My noctua's and case's fans are set at very low rpm's and are barely noticeable when the pc is not on load. then bump to 100% when cpu / case are too hot. quite a few things to tweak, but well worth it IMO.
CoreTemp vs. Speedfan Jake_HT O/S's, Drivers & General Software 4 January 21, 2009 12:16 AM
Speedfan & S.M.A.R.T Cypher^64 O/S's, Drivers & General Software 3 November 19, 2008 08:55 AM
Speedfan or CoreTemp ? Unklmo Overclocking, Tweaking and Benchmarking 4 April 12, 2008 12:53 PM
Speedfan Beta 18 released sswilson Press Releases & Tech News 15 February 20, 2008 06:50 PM
Speedfan 4.32 Update Babrbarossa Overclocking, Tweaking and Benchmarking 3 May 6, 2007 10:19 PM
