Hi All!
Let me know what you think.
I want to increase air intake in my Antec 300 by adding a side-window 120mm fan. This is what I ordered:
http://ncix.com/products/index.php?s....&promoid=1097
And
http://ncix.com/products/?sku=28875&...re=Mod%2FSmart
I realized that the fan I picked is a 4pin PWM (basically a CPU HSF replacement fan). So I made a mistake (well a $6.99 mistake...nothing to write home about)
So my P5Q pro was only one 4pin header (CPU FAN).
I have 3 free 3pin headers (chassis fan headers).
So I'll have to connect that 4pin fan in a 3 pin header...BAD? I can live with the full RPM (56 CFM).
Any risks of breaking something/shorting???
also, I was trying to determine the CFM of my Antec True Power TRio 650Watts (probably running at 400watts max load). Info on that is pretty hard to find especially when it's a PWM-controlled fan...
