<~----> So Fan1 on my New Rhoebus Fan controller won't spin or light up - Hardware Canucks
Old April 6, 2010, 08:42 PM
Default So Fan1 on my New Rhoebus Fan controller won't spin or light up
Defective I guess? So lame. RMA to newegg ugh so much of a pain.
Anyway to know for sure?
Old April 6, 2010, 09:07 PM
try another one? see that the wires are making proper contact. does it look/smell burned?
Old April 6, 2010, 09:10 PM
Yeah I tried swapping. The cable connection seems fine. no burns or w/e
Old April 6, 2010, 09:27 PM
This may sound stupid .... but look if it's really plugged in Fan1 .... same thing happened to me, turns out I had it plugged in into Fan4 by accident
http://www.thecomputermadesimple.com | The computer world in plain English!
Old April 6, 2010, 09:38 PM
All of them are occupied.
Old April 7, 2010, 09:55 AM
Soultribunal's Avatar
Well if you've swapped out to different fans in Port 1 then its time to RMA the controller.
Not much else you can do.
ST
Old April 7, 2010, 10:16 AM
martin_metal_88's Avatar
The Rhoebus is one of the best fan controller out here but we are never aware of defective unit. If you plug multiple fan in the slot 1 and they wont work but plugged in other channel they work then you have all you need RMA the best. Hope it will go fine, newegg have good RMA service so it should!
Ask for more
Martin_metal_88
Colenzo : See system spec!
Odysseus : I7 860 @ 3.6Ghz || GA P55-UD5 || G.skill Ripjaws F3-16000 2000Mhz 2X2GB || Coolermaster ATCS 840 || Silverstone Strider plus 850W || WD 640 black - WD 1TB green - Samsung F3 2TB || MSI 5670 1GB Cyclone ||Coolermaster Hyper 212 + ||
[WTB] fan controller. kyle_L Buy/Sell & Trade 13 January 4, 2010 02:23 PM
zalmaan 6 fan, fan controller quikgp Peripherals 4 May 29, 2009 09:32 PM
[FS] Rhoebus Extreme Fan controller ddude27 Buy/Sell & Trade 5 May 21, 2009 10:39 PM
PSU fan dont spin. loud. hot heat hohohee Power Supplies 14 April 13, 2009 04:59 PM
Fans Spin, Won't POST or Beep Scart Troubleshooting 11 July 29, 2008 03:42 PM
