Old April 1, 2010, 01:23 AM
M1K3Z0R's Avatar
Default Decent yet cheap 80mm LED fan?
Anyone have any suggestions on decent LED fans with a respectable cfm (for an 80mm) but still fairly quiet, or just low price?
I have a Thermaltake Xaser III and it can take up to 7 fans, I also have a fan controller that can take 4 3pin fans. I know 120mm fans are better but I don't wish to cut up my case, I like it as it is - but some of these fans I have in it are fairly weak and I've decided I want more lights... I'm a sucker for blue LEDs :P (although willing to mix it up and create a rainbow, no matter how "tacky" anyone thinks it looks)
Old April 1, 2010, 04:38 AM
Soultribunal's Avatar
I've always enjoyed Blue LED's as well so I know where you are comming from there.
For 80mm the choices are a little more limited at times. Thermaltake For a while had a real monster if you can still get it, their 80mm Smart Fan moves almost 50CFM , but given its size you pay the price for noise levels at that rate.
NCIX.com - Buy Silenx iXtrema Pro 80MM Blue LED Quiet Fan 1700RPM 32CFM 14DBA Fluid Dynamic Bearings 3/4PIN - IXP-54-14B In Canada.
SilenX has one that is actually half decent, moves about 32CFM (noise depends on location in the case) and uses a more modern Fluid Dynamic Bearing as opposed to cheaper variants.
NCIX.com - Buy Coolermaster TLF-S82-EB 80MM LED Case Fan 4 LED Blue 1800RPM 22CFM 22DBA - TLF-S82-EB In Canada.
Coolermaster has a Cheaper one, but it uses sleeve bearings which tend to have a higher failure rate than other types. It also moves less air.
Buy the Thermaltake AF0029 Thunderblade Clear LED Fan at TigerDirect.ca
Or you could try TT's Thunderblade.
If I personally had to choose, I'd opt for the SilenX first.
ST
Tags
80mm , cheapsauce , fan , led , xaser iii
Side 80mm Fan In vs. Out Dadi_oh Air Cooling 3 August 11, 2009 06:53 PM
Coolermaster cm690 80mm fan... somecanadianguy Air Cooling 18 April 21, 2009 02:02 PM
GOOD 80mm PSU on the cheap death_hawk Power Supplies 3 November 8, 2008 07:55 PM
FS:Zalman CNPS9500 LED Copper CPU Heatsink 92MM Fan 1350-2600RPM 18-27.5DBA Blue LED oksir Buy/Sell & Trade 0 July 14, 2008 12:24 AM
80mm fan djnocide Air Cooling 7 December 30, 2007 07:43 PM
