Old March 30, 2010, 04:02 PM
Default cpu cooler weight limit
i have just pruchased an asus P7P55D Deluxe. my question has to do with a weight limit for the cooler. like a lot i mount my mothrrboard in a case and then stand it up.
way back i had an msi motherboard. it had a weight limit of around 454 grams for the cpu cooler. i have been on the asus site and cannot find any such thing about the board.
does anyone know where this information can be found?
cheers and thx
rob123
Old March 30, 2010, 05:18 PM
Patramix's Avatar
i got the pro version and i really don't thing any mainstream coolers, even tower coolers are heavy enough to damage the board IF installed correctly, that means a Back plate must be present (for the cooler *cpu also as 1 so do mix them up* most coolers come with one now days.)
i had the HDT-S1283 on my old asus board without a back plate and it started bending and messed it up(i think the mofsat heat sink got away from them and overheated.
All of life is forged from Hell, Yet from its beauty our legacy began.
My Boinc Stats
Old March 30, 2010, 06:09 PM
Don't bother looking, 9/10 tower heatsinks go over the suggested weight limit for motherboards.
But that doesn't mean your motherboard won't be able to handle it, and it shouldn't void any warranties.
Asus, Gigabyte, Intel, from my personal experience use fairly rigid boards and they don't bend/warp no matter how much pressure/weight my cooler gives it. As long as you have a good backplate that is. The older Zalmans for example, come with really crappy plastic backplates.
Old March 30, 2010, 08:48 PM
if its a heavy cooler, if its attached right itll be ok..now if you drop your pc and the bracket or screws give way? hmmmm itll do some damage
Old March 31, 2010, 07:27 AM
Default NH-C12P SE14
thx for the assistance.
i have ordered the Noctua NH-C12P SE14. it garnered positive reviews. it comes with the necessary mounting hardware to allay concerns about weight.
rob123
Old March 31, 2010, 07:42 AM
CMetaphor's Avatar
Quadfather
As already stated, dont bother looking at weight "limits" as most heatsinks are over.
That being said, when installing a new and heavy HSF, if possible install it when the motherboard is Already attached to the case/motherboard tray. Many people install their huge heatsinks (especially on intel motherboards) before, which actually warps the motherboard.... then they fight to get the motherboard to flatten back out when installing it in the case/on the motherboard tray. The exception to this is when you have access to the back of the motherboard once its installed, because then you can also install the heatsink after the motherboard is in using a backplate.
Cooler Master V10 CPU Cooler Review Comment Thread AkG Air Cooling 60 October 22, 2011 01:52 AM
Cooler Master Hyper 212 Plus CPU Cooler Review Comment Thread AkG Air Cooling 268 April 16, 2010 03:23 PM
Cooler Master Hyper N520 CPU Cooler Review Comment Thread AkG Air Cooling 3 June 8, 2009 07:54 PM
[WTB] cpu cooler(LGA 775) and air cooler for 9800gt j-ronde Buy/Sell & Trade 0 March 11, 2009 10:06 PM
cpu cooler weight question in....... rob123 Air Cooling 6 March 22, 2008 08:30 PM
