  #41 (permalink)
Old June 17, 2010, 05:40 AM
Soultribunal's Avatar
Is there an RPM Fan wire on the Antec Ones Ultraman?
Regards,
ST
www.realhardwarereviews.com
  #42 (permalink)
Old June 17, 2010, 02:36 PM
ultraman7k's Avatar
they originally connect via 4 pin molex, so i guess not.
  #43 (permalink)
Old June 21, 2010, 08:09 AM
Default Replacement
Hi
I need a replacement for my Sunbeam fan controller.
This one seem to be a go bet.
What is the manufacturer warranty?
1 year?
  #44 (permalink)
Old June 22, 2010, 02:09 PM
JD JD is offline
So the FC6 should perform the same as the FC5? I'm mainly concerned with any possible whining.
  #45 (permalink)
Old June 23, 2010, 09:58 AM
I would imagine so, the Lamptron is really in a class of its own when it comes to fan Control.
I've sucessfully run 17+ Different Fans on it now without Fail , Whine, or issue. Not to say it isn't possible but in my honest opinion I don't forsee a Problem. It really proves which of my fans are good for undervolting and which to avoid (which is why I got it).
ST
  #46 (permalink)
Old June 23, 2010, 10:36 AM
AmuseMe's Avatar
It is exactly the same minus 10W. The FC6 is a 20W per channel controller while the FC5 is 30W. Oh, the FC6 also has a better screen on it at the moment. Lamptron plans on putting the FC6 screen on the FC5 in a later revision.
  #47 (permalink)
Old June 23, 2010, 10:55 AM
ok, so here's my plan for my FT-02, will this work?:
to use a bunch of these.. 3-Pin Y-Adapter Cable 6" Sleeved Products Model: 3PYSPLIT-6 [3PYSPLIT-6] : Performance-PCs.com, ... sleeve it and they will come
to have the 3 bottom fans on one knob, the 2 fans on the HS on a 2nd knob. and 1 on the case exhaust, and 1 extra one a 120mm fan i'll probably add to pull air out of the hdd area.
  #48 (permalink)
Old September 10, 2010, 04:04 PM
Patramix's Avatar
Anyone know where to find the updated FC5 V2 in canada? or FC6? been wanting one of them to finish my build off.
All of life is forged from Hell, Yet from its beauty our legacy began.
My Boinc Stats
Lamptron FC-2 fan controller mod (so it looks nicer on cases) IKIKUINTHENUTZ Cases 5 July 22, 2009 05:17 PM
HD 4770 Review Comment Thread SKYMTL Video Cards 58 July 21, 2009 01:34 PM
Thermalright HR-03 GT Review Comment Thread SKYMTL Water Cooling 9 April 10, 2008 01:52 PM
Comment Thread for Noctua NF-S12 Fan Review SKYMTL Air Cooling 4 May 30, 2007 08:06 PM
