Originally Posted by AkG I am not a fond lover (by any stetch of the imagination) of SilentX fans. There noise numbers are usually out to lunch...with the CFM numbers as a guest. ;)
Gelid fans are OK for a cooler. BUT if you have a SFlex E or F. That is the one I would use for my cooler. Great fan. |
I have a S-Flex SFF21F fan.
Yeah, I read mixed reviews on the SilentX but this is after I bought it. I guess I read the positive reviews first but since then, I read on one forum site, the consensus was quite negative and statements that there was some fishy specs/data or something like that. I am not a big fan of the look, btw.
I like the look of Noctua and Gelid fans but I know it depends on how it well it works and the design.
I can use the SilentX as a backup fan but then I would still need one more. ;)
I have a Yate Loon D12BL-12. Any good? I don't have screws with it though? I found 3 screws that look like the YL screws on the NCIX page for the YL fan, though. They're short and small, though. Not sure about it.
Sounds like I need to make some decisions, though, if I order a fan or two. ;) Might add a drive or another component, we'll see. :)
