Old March 25, 2010, 06:36 PM
Silvgearx's Avatar
Default E2180 stock heat sink for E8400?
I got a E8400 without the heatsink, so i been wondering if the E2180's stock heatsink would be fine for it. Since they both have the same TDP
I be using the E8400 @ stock speed
IntelŪ PentiumŪ Processor for Desktop E2180 - SLA8Y
IntelŪ Core?2 Duo Desktop Processor E8400 - SLAPL
Old March 25, 2010, 06:39 PM
Infiniti's Avatar
I've been using the smaller 45nm heatsinks for a Q6600, and it runs fine. Not sure if they're the same as the E2180 heatsink though.
Old March 25, 2010, 06:43 PM
misterd's Avatar
You'll be fine, but keep it @ stock or you're pushing your luck. I wouldn't be able to do it.
#hardwarecanucks on irc.freenode.net
fiat justitia ruat caelum
Old March 25, 2010, 06:48 PM
Silvgearx's Avatar
The stock HSF for the Q6600 is huge, are you sure your fine with a 45nm version?
I also have a vendetta siting here but its so damn tall
I won't be able to overclock on a G31 board No need to worry about 400FSB
Good thing this E8400 is lapped, a few C lower, now I just need those noctua TIMs from NCIX
Old March 25, 2010, 07:04 PM
the best stock coolers up to the new cpus using a tower cooler style have been the pentium d's ones. copper core, bigger and heavier. only downturn is a crappily noisy fan, high cfm but noisy as fudge. nothing a zip tie or two and a quieter 120mm cant fix.
Old March 25, 2010, 08:10 PM
Silvgearx's Avatar
Was gonna use one of those arctic low profile ones, but I forgot to order it at ncix
Arctic Cooling
Old March 26, 2010, 07:31 AM
misterd's Avatar
I got 3.4 out of some Q6600's on G45 P5Q-VM with Xigmatek 1283. Just running BOINC on 15 of them blew the AC in the room... there goes the farming.
Old March 26, 2010, 02:23 PM
Silvgearx's Avatar
Those Q6600 produce quite a bit of heat, I hate a TRUE 120 with push and pull on one of them and the heatsink was warm to touch
Dang, time to upgrade the AC eh
Old March 26, 2010, 02:43 PM
g31 ocs if it has the option(s). power filtering and mobo cooling worries me a tad, especially with a quad.
Help Heat Sink SEVEN Troubleshooting 6 July 25, 2009 07:28 AM
Heat sink comparison Bones Air Cooling 11 March 27, 2009 05:07 PM
CPU Heat sink WolfBane Air Cooling 4 March 8, 2009 09:58 PM
best air cooling heat sink to use for the E8400? Gameplaywarrior Air Cooling 27 December 8, 2008 10:33 AM
What is the highest OC you can safly get on the 9800GTX+ SC with the stock heat sink? 49-parallel Overclocking, Tweaking and Benchmarking 0 September 18, 2008 10:36 AM
