Old March 25, 2010, 06:20 AM
Default Noctua NH-U12P, CM Hyper 212+, CPU HSFs...
Hey guys,
I've been lurking for a while now, but have decided to post to ask for your opinions. I've wanted to replace the stock cooler on my Q6600 for a while now and was originally going to go with the CoolerMaster Hyper 212+ due to it's cost/performance ratio.
The confusion comes in because NCIX's weekly sale has the Noctua NH-U12P on sale for $49.99, which isn't bad.
I don't overclock; okay, well, I haven't over clocked in the past. I don't have a rule that says I'll never over clock. In your opinion, would it be worth paying $49.99 for the Noctua, when you can price match the 212+ at NCIX and get it for under $25, in my situation? Will I seem much of a difference at stock to mid-OC?
Old March 25, 2010, 06:28 AM
AkG's Avatar
AkG AkG is offline
Hardware Canucks Reviewer
Your going for low OC at the most? Get the 212+.
Noctua's are great coolers, but they would be overkill for stock and mild overclocks. You'll love the 212+.
Old March 25, 2010, 07:22 AM
Thanks, AkG. I suspected as much. I went ahead and ordered one from NCIX. Now to wait for delivery...
Old March 25, 2010, 08:14 AM
did you pricematch for 22$? :)
Old March 25, 2010, 08:17 AM
I did! Pending approval. Price-matched a set of CM R4s for $5.50 too. Decent enough price, and I need to play with the fans in my case to get the noise level to what I want. We'll see!
Old March 25, 2010, 08:23 AM
not too bad. do you have a fan controller? i used to find the
Sunbeam 4 Port Rheobus
pretty cheap(15-20$) but theyre out of stock now forever. only thing to do is to remove the stupid leds as theyre extremely bright. just pull the feet out their socket, job done
Old March 25, 2010, 09:00 AM
I don't have a fan controller as of yet. Though I've thought about just slapping one together myself.
This is a little off-topic, but one thing I've never understood about things like the Sunbeams is their absurd power ratings.
Take, for example: Sunbeam Rheobus-Extreme 6-Channel Fan Controller - Black (RHK-EX-BK) - FrozenCPU.com
180W total and 30W per channel? Why?
Newegg.ca - COOLER MASTER R4-BMBS-20PK-R0 Blade Master 120mm Case Fan - Case Fans
I've seen AkG suggest the BladeMasters a few times (and I believe they are what come on the Hyper 212+ units). It's rated for 12VDC@0.36A, or 4.3W. That would allow for somewhere in the realm of forty of these fans.
Old March 25, 2010, 09:16 AM
AkG's Avatar
AkG AkG is offline
While I cant comment on the Sunbeam....I KNOW for a fact that Lamptron is very conservative in their numbers. I ran nearly 40 watts off one channel (many, MANY fans and an arse load of adapters) for over an hour on a FC-5 and it didnt even blink! The Lamp FC-5 is a BEAST and if you are looking for a fan controller that is the one I would recommend. :)
Old March 25, 2010, 09:31 AM
Soultribunal's Avatar
Flexibility and redundency for sure. That way no matter how messed up your Cooling Scenerio is you have a controller that can handle it. Up to and including the 10W 256CFM Delta Fans.
I'd rather have something that has such a high specification than running a 4W fan on a 4W controller.
That being said, Good Choice on the R4's. Very solid fan minus the use of Sleeve Bearings.
ST
Old March 25, 2010, 09:37 AM
Oh, absolutely. I suppose it was just my first reaction to look at it's ratings and think "wow, that's silly." Hats off to the guy who can sit beside a machine running 180W of air cooling though and not lose his mind (or his footing). Haha.
Cooler Master Hyper 212 Plus CPU Cooler Review Comment Thread AkG Air Cooling 268 April 16, 2010 03:23 PM
Noctua NH-U12P CPU Cooler Review comment thread AkG Air Cooling 8 May 27, 2008 04:34 PM
Noctua NH-U12P Heatpipe CPU Cooler Hardware Canucks Air Cooling 0 May 5, 2008 12:32 PM
