Old March 20, 2010, 09:09 PM
DANGERDOOM64's Avatar
Default cpu cooler question!
So i'm looking at two cpu coolers right now, the Cooler Master V8 and Corsair H50, not sure which one is better. I have read the review on this site for the V8, i'm going to be running a core i5 750 and OC it to maybe 3ghz or 3.2ghz. If i'm right, the price is about the same on both units. So anyone have a suggestion or something between the two? Just want the one that will keep my i5 running the "coolest"..haha...
thanks for any help!! Oh, and I am going to have them in a Antec 1200 case, if the means anything.
Old March 20, 2010, 09:11 PM
Between those two go with H50. you'll get better temps.
"What is the colour when black is burnt ?" - Neil Young
Old March 20, 2010, 09:16 PM
no love for the contact core from sunbeam? you can find one for about 25-30$ and very hard to beat per dolalr spent.
but yeah, between those two h50
Scythe Intel LGA775 Heatsink Temperature Comparison - Grand Kama Cross SCKC-2000 FrostyTech Review
they have a 150w limitation, but decent nonetheless.
Tuniq Tower 120 Extreme high 14.1 8.4 43.5 Noctua NH-D14 high 14.5 8.7 48.1 Prolimatech Megahalems (80CFM) high 15.0 9.2 53.0 3Rsystem iceage 120 Boss II high 15.4 9.8 49.9 Titan TTC-NK85TZ high 15.5 8.8 58.6 Thermolab BADA high 16.0 9.6 54.0 Sunbeamtech Core-Contact Freezer high 16.1 10.0 51.3
Old March 20, 2010, 09:24 PM
The H50 is definitely the best out of those two. And much better than the Sunbeam Core Contact Freezer that dangtx suggested; the Sunbeam is a great budget cooler, but can't compare to the high-end stuff.
Old March 20, 2010, 09:41 PM
Sushi Warrior's Avatar
The V8 is not a very good cooler. I would suggest the Coolermaster Hyper 212+ as it refines the Sunbeam CCF even further (well, it's mostly based on HDT.... still). The H50 is only really good if you can't fit a 120mm cooler into your case or don't want all the strain of a big cooler on your mobo.
Old March 20, 2010, 09:49 PM
thanks for the help!
definitely going with the H50 then, i'm thinking about doing a push/pull configuration on it (think i used the right term), any suggestions for the best fan for the job?
Old March 20, 2010, 09:53 PM
MonsterSound's Avatar
A bit off topic, but you might just find yourself overclocking the i5 750 a tad more than 3.2ghz as it so easily overclocks on stock volts ~3.5ghz and at reasonable temps. Just a thought.
Code:
 my Heatware,  RFD &  eBay
MAIN: i5 3570 @ 4.5Ghz wH100 / evga GTX780 SOC / MSI Z77A-G45 / 8gb G.Skill 2133 1T / 30" 2560x1600 / Antec P280 / PCP&C 950w / Intel 520 SSD 240gb / Eclipse / G3-Lazer / z5300 / Win7 Pro64 / APC Xs1300
HTPC : nMedia6000B / AMD X2 4400+ / M2A-VM / Corsair 4GB 800 / LiteOn Blu-Ray / 8800GT / Samsung 46"LCD / 2x2TB / OCZ500 / ATI550 / Wrless Kbrd & Rmte / z-5500 / Win7Pro / APC700
"You must be the change you want to see in the world"
- Mahatma Gandhi
Old March 21, 2010, 07:59 AM
martin_metal_88's Avatar
I have own a H50 previously and Push pull is the best config you can do. Also try to find a place in the case where it wont blow the video card exhaust or the hotair over the CPU. Mine was placed in the top fan mount of my ATCS 840. It would have been nice if the tube were long enough to place it in the front or in the bottom.
Cooler Master V10 CPU Cooler Review Comment Thread AkG Air Cooling 60 October 22, 2011 01:52 AM
Cooler Master Hyper 212 Plus CPU Cooler Review Comment Thread AkG Air Cooling 268 April 16, 2010 03:23 PM
Cooler Master Hyper N520 CPU Cooler Review Comment Thread AkG Air Cooling 3 June 8, 2009 07:54 PM
Question about CPU cooler Alex1441 Air Cooling 3 August 30, 2008 07:13 PM
cpu cooler weight question in....... rob123 Air Cooling 6 March 22, 2008 08:30 PM
