  #21 (permalink)
Old March 14, 2010, 09:09 AM
Originally Posted by RLP06 View Post
It works perfectly fine when I use Speedfan and set it to allow the fan to only spin at 50% of max speed. I also have a Zalman Fanmate 2, but I just don't want to have to use an external solution. Cooling isn't the problem, its the fan spinning faster than necessary (which might actually be the settings, but can't find where).
I just tried PWM mode, no luck... : (
well thats your solution i guess
  #22 (permalink)
Old March 14, 2010, 09:46 AM
Its A solution, obviously not optimal, as I'd prefer not to have to use external software (as another poster mentioned, this shouldn't be necessary)
The mobo has on default 25 degrees as the starting point to vary speed. I've used EasyTune 6 (the software that comes with the gigabyte mobo to set it to 40), but it just won't stay there permenantly, when I reboot, it'll spin fast, and then when it gets into windows, the software kicks in.
I guess this now becomes a question for people with Gigabyte mobos and how they've dealt with this, I'm sure theres a solution other than speedfan.
New on HWC but lots of feedback on RFD (89-0-0)
XBMC Rig (1900PPD): AMD Athlon II X2 240 @ 3.2ghz | Gigabyte GA-MA78LM-S2H | G.Skill 2GB DDR2 800 | WD Caviar Blue 500GB | Antec NSK1300 SFF Case
Folding Rig: (1700+4500PPD) Intel Core 2 Duo E6600 | Gigabyte GA-P35-DS3L | OCZ Special Ops 2GB DDR2 800 | EVGA 9800GT | G.Skill Falcon 64GB SSD | Samsung Spinpoint 1TB | Seagate Momentus 1TB | Generic ATX 430W Case
  #23 (permalink)
Old March 14, 2010, 10:59 AM
stoanee's Avatar
Can you change the setpoints in bios higher? 25C is low and you should be able to set your fans to ramp up at a higher temp.
heatware
  #24 (permalink)
Old March 15, 2010, 09:36 PM
Nope, not possible. Oh well, I've settled on the EasyTune6 solution
Thanks for all the help
  #25 (permalink)
Old March 17, 2010, 01:40 PM
Soultribunal's Avatar
I actually think mate that that is normal operation for PWM Fans. If set to temp controlled all PWM Fans should spool up fast on booting normally then level off. Stop using your other programs to control it and run a normal cycle of off - on and see if once it gets into windows you are fine.
I think you have normal operation here now, unless I'm missing something.
ST
www.realhardwarereviews.com
  #26 (permalink)
Old March 18, 2010, 07:48 PM
ST
It's still a bit too loud even without any software, it does slow down from the fast on booting, but not enough to keep me happy.
I think the problem may be that the motherboard is reading a different temperature than the core of my cpu, thus the motherboard thinks the cpu needs cooling? I'm still trying to figure that one out in my other thread
CoreTemp32 or Motherboard reading, which is right?
I hope you guys don't think I'm completely dumb by now, but I'll admit, I'm still catching up to speed from about 5-6 years away from caring about hardware.
XFX GeForce GT 240 Released FiXT Press Releases & Tech News 4 November 17, 2009 10:24 PM
ATI HD4850 fan noise problem Chris Video Cards 20 August 12, 2009 07:50 AM
gtx 275 is making noise... (not the fan) lexmark1 Video Cards 19 May 20, 2009 04:22 AM
What's the best performance & low noise 120mm fan? appplejack Air Cooling 8 January 15, 2009 10:21 PM
Athlon 64 x2 5600 (Windsor) runs HOT and fan goes crazy ! DarKStar Troubleshooting 3 July 29, 2008 04:52 PM
