Old March 13, 2010, 08:33 AM
I'm looking at a 3rd party cooler as a last resort really, but this is my low budget build. I'm just wondering if I'm missing a mobo setting that is causing it to spin so fast, because I think its the RPM's that's the problem,not the fan itself.
New on HWC but lots of feedback on RFD (89-0-0)
XBMC Rig (1900PPD): AMD Athlon II X2 240 @ 3.2ghz | Gigabyte GA-MA78LM-S2H | G.Skill 2GB DDR2 800 | WD Caviar Blue 500GB | Antec NSK1300 SFF Case
Folding Rig: (1700+4500PPD) Intel Core 2 Duo E6600 | Gigabyte GA-P35-DS3L | OCZ Special Ops 2GB DDR2 800 | EVGA 9800GT | G.Skill Falcon 64GB SSD | Samsung Spinpoint 1TB | Seagate Momentus 1TB | Generic ATX 430W Case
Old March 13, 2010, 09:03 AM
like i said, possibly the fan control is borked or doesnt work well with that one fan. in bios you can put it on auto, quiet,medium,etc right?
Old March 13, 2010, 11:02 AM
The bios has "Auto", "Voltage" or "PWM". Wish it had a quiet setting, lol
Old March 13, 2010, 12:47 PM
stoanee's Avatar
Have you tried them all?
Old March 13, 2010, 04:28 PM
Soultribunal's Avatar
The fan in my Fathers Rig Spun in around 2300 RPM and It never kicked in until 60 or so.
I Think Stoanee is right though with trying those settings. PWM is the control for CPU Fans.
Just outta dumb curiosity, you do have it plugged into the CPU Fan Header (4-pin) right?
All else fails I think perhaps the PWM Controller is shot, or the Fan is not working right, or there is a setting missing. BEcause I've never once in my life needed Software to take care of my CPU Fans. BIOS always did the job.
ST
The Below statement is True
The Above statement is False
Old March 13, 2010, 06:50 PM
Thanks guys, will try PWM when I'm back at my apartment. I tried Auto and Voltage, Voltage made it spin faster.
Fingers crossed for PWM :)
Old March 13, 2010, 07:04 PM
ST
Yep, the fan is plugged in correctly, there is no other way of plugging it in I don't think, it won't really fit any other way.
Old March 13, 2010, 08:15 PM
would you be ready to yank it out and mod something on top of the stock cooler or going with a third party solution? look up the fs ft section here, you can get great coolers for a fraction of the price, sometimes :)
  #19 (permalink)
Old March 13, 2010, 08:18 PM
jcmaz's Avatar
Where is the OP located?
-Plato
  #20 (permalink)
Old March 14, 2010, 09:56 AM
It works perfectly fine when I use Speedfan and set it to allow the fan to only spin at 50% of max speed. I also have a Zalman Fanmate 2, but I just don't want to have to use an external solution. Cooling isn't the problem, its the fan spinning faster than necessary (which might actually be the settings, but can't find where).
I just tried PWM mode, no luck... : (
XFX GeForce GT 240 Released FiXT Press Releases & Tech News 4 November 17, 2009 10:24 PM
ATI HD4850 fan noise problem Chris Video Cards 20 August 12, 2009 08:50 AM
gtx 275 is making noise... (not the fan) lexmark1 Video Cards 19 May 20, 2009 05:22 AM
What's the best performance & low noise 120mm fan? appplejack Air Cooling 8 January 15, 2009 10:21 PM
Athlon 64 x2 5600 (Windsor) runs HOT and fan goes crazy ! DarKStar Troubleshooting 3 July 29, 2008 05:52 PM
