Old March 9, 2010, 08:36 PM
Soultribunal's Avatar
Originally Posted by SugarJ View Post
The PWR fan header is meant to run a ESA controlled fan in a PSU. It can be used as a normal fan header without issues. I wouldn't use the 4 pin header unless you run out of 3 pin headers.
Gotcha, I figured as much just never realized that they still really had those features kicking around ( I Think ANtec is the only one top of the head that supports it).
As for the 4-pin, its prefectly fine to use, and it allows full MB control of the Fan still in BIOS.
Thats how all my R4's are wired to their respective coolers.
ST
www.realhardwarereviews.com
Old March 9, 2010, 08:49 PM
ZZLEE's Avatar
Default Donn't Know Asus
With my Evga ypu can ajust fan speed in BIOS with somthing called smart fan or manule fan speed settings.
Havin't played with AUSUS BIOS
"EVGA hunted down the last dozen or so expats living in Karachi." SKY
Installing 250mm cooling fan in your case Mnpctech Guides & How-to's 9 May 30, 2011 05:38 PM
HELP Fan connections with CM932 case? johndh New Builds 3 December 15, 2009 09:49 PM
140 mm case fan Inik Air Cooling 8 November 16, 2009 01:01 PM
[WTB] Fan screws to mount to case Lpfan4ever Buy/Sell & Trade 13 October 2, 2009 11:11 AM
Case fan speed!! Jarod_g29 Air Cooling 2 March 9, 2008 06:11 PM
