Originally Posted by Zero82z Are you talking about plugging the 4-pin female molex connector from the fan into the male molex connector on the motherboard? If that is what you mean, then no, you can't do that. |
no, its a three pin without the adapter. I know it will plug in i'm just not sure if my pc with blow up or something haha. reading on another forum that it will work as long as the fan has three live wires
trying something new, instead of buying a low pro 80mm fan for the right side of my 690 i'm gonna stick a stock cpu heatsink fan over there as when you place it off axis (like a diamond) up to the side panel vent/holes the top and botto hole seem to line up perfect so i would just attatch it to the sidepanel instead of inside the case where the 80mm fan would go. just need to get an extension cause the wire wont reach
