Originally Posted by AkG Venom X is a very good cooler. Almost as good as the other top of the line kit, like Prolimatech. The improved fin design does allow it to "like" lower static and speed fans better than the TRUE, but I'd still take a Noctua or Prolimatech or maybe even a Zalman CNPS10X Flex. for low speed setups you cant beat the Prolimatech coolers. :)
The biggest weakness the Venom X has is it has a SMALLER fin array than a TRUE this limits it at higher heat loads. IF they make an "eXtreme" version it would be an awesome cooler, but as it stands its very good...but not great. |
I'm planning to use it with a low RPM 120mm fan. I'm looking at the Venom X because my Ultima 90 can't be used with my LGA1156 setup so I mind as well get something that is not only compatible with my i5 750, but also perform better. Another reason why I'm opting for the Venom X is that it's C$59.99 at Ncix while it seems like the other coolers are more expensive. Can you point me to a source that will sell other good heatsinks for low RPM setups for less than C$59.99?
