Old February 25, 2010, 08:18 PM
Default i7 920 in cm 690II
Recommendations for a good quiet cooler for a 920 @ around 4ghz in a cm 690 II advanced. I want acceptable temps but nice and quiet too. I'm ok with spending extra for better fans than a stock cooler provides.
Old February 25, 2010, 08:35 PM
kruzn4evr's Avatar
Corsair H50??...I know you said air cooler but why go air when you can go with the H50 and probably achieve your goals.....just my 2 cents worth
Old February 25, 2010, 09:11 PM
Nothing against the h50 but is a pump with a fan going to be any quieter than a heatsink with a fan? I have read that the pump noise on a h50 can be quite annoying.
Old February 25, 2010, 09:17 PM
SugarJ's Avatar
To aircool a 920 at 4 ghz you're going probably going to need a fan with a lot of CFM, and noise.
Old February 25, 2010, 09:19 PM
Arinoth's Avatar
I'd recommend the Cooler Master Hyper 212+, got it in my CM 690 with some nocta fans mounted on them and some good air flow in the case. I typically will see temps around 70C max full load folding when my room is around 22-24C, and temps much lower as my room temp goes down (if i'm around 17-20C i'll see full load of temps as low as 55C).
I should note i at 3.8GHz and using the hotter C0/C1 revision rather then the cooler D0 which i assume you'll have if you are or have bought it recently.
Here I am: here I remain
Old February 25, 2010, 09:26 PM
bojangles's Avatar
D0's can be just as hot as C0/C1's. They're just awesome on voltage :). The CM Hyper 212+ will be a good pick for a low budget cooler.
Old February 25, 2010, 10:06 PM
Silvgearx's Avatar
Even with noctuas, more fan = more noise. Quiet is almost none existence with high overclocks on fan cooling. Unless you put them in a different room. And most of the time its the gpu thats loudest in the whole system.
My gtx 260's stock fan is louder than all 6 fans rated at >20dba.
Old February 26, 2010, 10:52 AM
I'll second the 212
[WTB] i7 920 3.0charlie Buy/Sell & Trade 8 January 5, 2010 07:48 PM
[WTB] i7 920 kyle_L Buy/Sell & Trade 1 November 23, 2009 07:59 AM
i7 920 LC0g Overclocking, Tweaking and Benchmarking 7 July 6, 2009 12:36 PM
I7 920 is there HT elec999 CPU's and Motherboards 3 June 2, 2009 05:42 AM
help me WC a i7 920? go flames go Water Cooling 16 April 10, 2009 07:22 AM
